Redbeard
Official Corsair Rep.
- Nov 3, 2005
So after I find the above and decide that a sharpie will fix the problem and after I build my rig and do all of the cable management I find out that my far left (looking at the front of the case) USB 3.0 port/cable does not work.
Redbeard what do you suggest that I do? Can I just have a front panel sent to me?
We can send a replacement I/O panel I believe.
You might want to check and make sure there's no loose connection on the backside of the I/O panel, but if you still can't get it working email me: redbeard@corsair.com and I'l send you a new piece.
And I'll say this one more time: The H100 works on ALL Corsair cases from the $99 400R to the $299 800D.
