Hello everyone
I have a "slight" problem with my server.
It's been running without any sign of trouble since the beginning of March, but now it is completely unable to boot. I'm getting no signal through to the monitor and I'm pretty sure that it's not entering windows as I'm not able to access it over the network in anyway.
I've tried two different GFX cards that are confirmed working in other machines, my motherboard has 2 PCI-e slots and I've tried both cards in both slots.
I only have 4 GB of ram in it, which is a couple of dual channel ram sticks, and I've tried both in slot 0 with no change whatsoever.
I'm getting no post beeps from the builtin speaker - I first thought it was because I inserted the speaker cable reversed, but switching it around made no difference, and I'm actually not sure if it ever made the 1 beep signally a successful start, when the computer worked...
When firing up the computer everything starts to spin, PSU, CPU, GFX and all harddisks start up, but after a few blinks the HDD LED stops blinking, the fans keep spinning but nothing else happens...
I feel that I'm starting to run out of options, but I would really like to hear you guys opinions.
Following is a list of all the gear in the computer:
GIGABYTE GA-P55M-UD2
Intel Core i3 530 (2.93 GHz), Clarkdale, Dual Core, 1333FSB, 32nm, 4MB Cache (LGA1156)
Corsair 2x2048MB DDR3, PC10660, DDR1333, CAS 9
Western Digital 1000 GB x 2
Western Digital 2000 GB x 1
Radeon HD 4350, 1024MB DDR2
Any help is grealy appreciated
