Computer setup help
I need some help deciding on a computer to get to to replace my laptop. I am a gamer and my laptop barely has the specs to run right. I need a computer that has or can do the following:
Mostly gaming and some animation software( For the games The most demanding game I would think would be Dead Space 3 and for animation I use Unity)
I would like to say 600 is a safe price but I might be able to go to 700
I live in El Paso TX
Im going to need the CPU, RAM, Video Card, etc. I'm not a big computer guy, I am not familiar with naming all of the parts sorry.
I am not doing to be reusing any parts
6) Will you be overclocking?
If it is possible more then likely
I have a 1080P 3D monitor
Hopefully in the next month or two
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Just the stuff to run what I had listed earlier. Sorry if I am not listing all of the items because I am not familiar with them all.
I do not but I would prefer Windows 7 64-bit
Please let me know if you have any suggestions for this. I have a friend who can build it if a pre-built kit is to expensive. Thanks Guys!
Hola from El Paso! We are FAR away from a Microcenter. I am not going to post links. The site I use isn't viewed upon kindly here, and I hate searching the recommended one. I don't mind spending my money with the recommended one, I just hate trying to find stuff there :)
CPU: Core i5 3350P (This CPU has no integrated graphics, and is an Ivy Bridge CPU) $185'ish
Motherboard: Most B75 chipset motherboards. Pick your favorite brand. These have USB 3.0, SATA 6G, Gb ethernet, etc. $70'ish
Memory: $90 or so for 16GB (2X8GB) of a good brand. You could get away with 8GB most likely, but prices are creeping up, and most of the B75 chipset motherboards only have two ram slots.
OS: $100 for Win7 64-bit Home Premium OEM.
Videocard: Figure $200+ for a video card you would want to use (GTX 660 or Radeon 7850. 2GB memory for either.
You didn't mention storage, but my list above takes you over $600 unless you go for 8GB ram or don't need an OS. Looking at the FS/FT forums here wouldn't be a bad place to look either. Sign-up for the major e-tailers mailing lists or daily specials. Can find some good stuff there too.
Good luck.
Good luck.
could you mssg me the links?
Don't go with artimusbill's outline since it doesn't include a PSU or case. As such, it would far far outside your budget.
Now again: Since you don't have have a legit and reusable OS key, is the cost of a new OS key part of that $600 budget? Or is part of a seperate $100 budget?
Sorry my phone double posted it
It wouldn't be separate unless i still have my windows vista one
All right I recommend this build instead:
$124 - Intel Core i3-3220 CPU
$73 - Gigabyte GA-B75M-D3H Intel B75 mATX Motherboard
$46 - Corsair CMX8GX3M1A1333C9 8GB DDR3 1333 RAM
$120 - Sapphire Radeon HD 7770 Ghz 1GB PCI-E Video Card
$74 - Western Digital Blue WD10EZEX 1TB 7200RPM SATA 6.0Gb/s Hard Drive
$18 - LG iHAS124-04 DVD Burner
$45 - Corsair 430CX V2 430W PSU
$60 - Corsair Carbide Series 200R ATX Case
$92 - Windows 7 Home Premium SP1 64bit OEM
Total: $652 shipped
A bit over budget but it's gonna be your best bet for the cheapest bang for the buck setup.
