Client issues
Shambler
Installed FAH GPU tracker V2.
Options:
Enable CPU folding
Use Multicore SMP
Use All cores
Enable GPU folding with GPU0 selected
Set my name and Team#
GPU folding is going great. CPU folding shows CPU disabled, with SMP running. Project 6701, 921 Points, 0% complete. I started this a few hours ago.
Ideas?
Rig in sig.
SMP Log
--- Opening Log file [October 26 16:33:29 UTC]
# Windows SMP Console Edition #################################################
Folding@Home Client Version 6.30
http://folding.stanford.edu
Launch directory: C:\Users\Phenom\Folding\FAH GPU Tracker V2\SMP
Executable: C:\Users\Phenom\Folding\FAH GPU Tracker V2\FAH.exe
Arguments: -oneunit -forceasm -smp
[16:33:29] - Ask before connecting: No
[16:33:29] - User name: Shambler (Team 33)
[16:33:29] - User ID: 53BBC1257AE3A2BF
[16:33:29] - Machine ID: 2
[16:33:29]
[16:33:29] Work directory not found. Creating...
[16:33:29] Could not open work queue, generating new queue...
[16:33:29] - Preparing to get new work unit...
[16:33:29] Cleaning up work directory
[16:33:29] + Attempting to get work packet
[16:33:29] - Connecting to assignment server
[16:33:29] - Successful: assigned to (171.64.65.56).
[16:33:29] + News From Folding@Home: Welcome to Folding@Home
[16:33:29] Loaded queue successfully.
[16:33:31] + Closed connections
[16:33:31]
[16:33:31] + Processing work unit
[16:33:31] Core required: FahCore_a3.exe
[16:33:31] Core found.
[16:33:31] Working on queue slot 01 [October 26 16:33:31 UTC]
[16:33:31] + Working ...
[16:33:31]
[16:33:31] *------------------------------*
[16:33:31] Folding@Home Gromacs SMP Core
[16:33:31] Version 2.22 (Mar 12, 2010)
[16:33:31]
[16:33:31] Preparing to commence simulation
[16:33:31] - Assembly optimizations manually forced on.
[16:33:31] - Not checking prior termination.
[16:33:32] - Expanded 763574 -> 1404481 (decompressed 183.9 percent)
[16:33:32] Called DecompressByteArray: compressed_data_size=763574 data_size=1404481, decompressed_data_size=1404481 diff=0
[16:33:32] - Digital signature verified
[16:33:32]
[16:33:32] Project: 6701 (Run 59, Clone 15, Gen 58)
[16:33:32]
[16:33:32] Assembly optimizations on if available.
[16:33:32] Entering M.D.
[16:33:58] Completed 0 out of 2000000 steps (0%)
shambler, you are one scary dude. I can't tell you how many times you shambled me.
oh, on topic: maybe could you post a screenie of the Tracker app? I'm not entirely familiar with the specifics of how it works
lollerskates
Hope the pic shows up:
Nope. Can't see it.
As for your log, there's one difference - it should look like this:
Launch directory: D:\BENCHM~1\FAH
Service: D:\BENCHM~1\FAH\SMP.exe
Arguments: -svcstart -d D:\BENCHM~1\FAH -local -verbosity 9 -smp 6 -forceasm
Launched as a service.
Entered D:\BENCHM~1\FAH to do work.
[18:28:10] - Ask before connecting: No
[18:28:10] - User name: Mr._Pedantic (Team 33)
[18:28:10] - User ID: 508DC76E16C08206
[18:28:10] - Machine ID: 3
[18:28:10]
[18:28:10] Loaded queue successfully.
[18:28:10]
[18:28:10] - Autosending finished units... [October 26 18:28:10 UTC]
[18:28:10] + Processing work unit
[18:28:10] Trying to send all finished work units
[18:28:10] Core required: FahCore_a3.exe
[18:28:10] + No unsent completed units remaining.
[18:28:10] - Autosend completed
[18:28:10] Core found.
[18:28:10] Working on queue slot 02 [October 26 18:28:10 UTC]
[18:28:10] + Working ...
[18:28:10] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 6 -checkpoint 3 -service -forceasm -verbose -lifeline 3532 -version 630'
[18:28:11]
[18:28:11] *------------------------------*
[18:28:11] Folding@Home Gromacs SMP Core
[18:28:11] Version 2.22 (Mar 12, 2010)
[18:28:11]
[18:28:11] Preparing to commence simulation
[18:28:11] - Ensuring status. Please wait.
[18:28:21] - Assembly optimizations manually forced on.
[18:28:21] - Not checking prior termination.
[18:28:21] - Expanded 764047 -> 1404481 (decompressed 183.8 percent)
[18:28:21] Called DecompressByteArray: compressed_data_size=764047 data_size=1404481, decompressed_data_size=1404481 diff=0
[18:28:21] - Digital signature verified
[18:28:21]
[18:28:21] Project: 6701 (Run 2, Clone 9, Gen 68)
[18:28:21]
[18:28:21] Assembly optimizations on if available.
[18:28:21] Entering M.D.
[18:28:28] Using Gromacs checkpoints
[18:28:29] Resuming from checkpoint
[18:28:29] Verified work/wudata_02.log
[18:28:29] Verified work/wudata_02.trr
[18:28:35] Verified work/wudata_02.xtc
[18:28:35] Verified work/wudata_02.edr
[18:28:36] Completed 1723310 out of 2000000 steps (86%)
Difference bolded.
I don't know much about exactly how the core works, but I'm pretty sure this means that it's not being used. Check the Task Manager, see if it shows up.
Nope. Can't see it.
You have -verbosity 9 turned on, he doesn't, that is why you are seeing more detail including the actual core command line.
Well in the meantime: I stopped the SMP portion from FAH Tracker and started up the standard Windows sys tray client.
Oddly enough, my 6 core was hitting 100% usage with SMP turned on. Now with that stopped, and the standard client running, I'm barely hitting 45%.
Hmmm.
True, forgot about that. My bad... :p
I can see the image if I open it directly.
It seems to be properly set up. And the fact that your single threaded client seems to be folding fine adds to the mystery.
I am having the same issue, which I posted in the main easy thread. 4 cores at 100% with SMP but won't go past 0%. Normal SMP that I installed manually works fine. Windows 7 64-Bit in case that has anything to do with it.
SMP Log
--- Opening Log file [October 27 02:58:44 UTC]
Launch directory: G:\FAH\FAH GPU Tracker V2\SMP
Executable: G:\FAH\FAH GPU Tracker V2\FAH.exe
Arguments: -oneunit -forceasm -smp -verbosity 9
[02:58:44] - Ask before connecting: No
[02:58:44] - User name: travanx (Team 33)
[02:58:44] - User ID: 69F52069215BC472
[02:58:44] - Machine ID: 2
[02:58:44]
[02:58:44] Work directory not found. Creating...
[02:58:44] Could not open work queue, generating new queue...
[02:58:44] - Preparing to get new work unit...
[02:58:44] - Autosending finished units... [October 27 02:58:44 UTC]
[02:58:44] Cleaning up work directory
[02:58:44] Trying to send all finished work units
[02:58:44] + No unsent completed units remaining.
[02:58:44] - Autosend completed
[02:58:44] + Attempting to get work packet
[02:58:44] Passkey found
[02:58:44] - Will indicate memory of 6134 MB
[02:58:44] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 14, Stepping: 5
[02:58:44] - Connecting to assignment server
[02:58:44] Connecting to http://assign.stanford.edu:8080/
[02:58:44] Posted data.
[02:58:44] Initial: 40AB; - Successful: assigned to (171.64.65.56).
[02:58:44] + News From Folding@Home: Welcome to Folding@Home
[02:58:44] Loaded queue successfully.
[02:58:44] Sent data
[02:58:44] Connecting to http://171.64.65.56:8080/
[02:58:45] Posted data.
[02:58:45] Initial: 0000; - Receiving payload (expected size: 763901)
[02:58:46] - Downloaded at ~745 kB/s
[02:58:46] - Averaged speed for that direction ~745 kB/s
[02:58:46] + Received work.
[02:58:46] + Closed connections
[02:58:46]
[02:58:46] + Processing work unit
[02:58:46] Core required: FahCore_a3.exe
[02:58:46] Core not found.
[02:58:46] - Core is not present or corrupted.
[02:58:46] - Attempting to download new core...
[02:58:46] + Downloading new core: FahCore_a3.exe
[02:58:46] Downloading core (/~pande/Win32/x86/Core_a3.fah from www.stanford.edu)
[02:58:46] Initial: AFDE; + 10240 bytes downloaded
[02:58:46] Initial: D8B1; + 20480 bytes downloaded
[02:58:46] Initial: 7D98; + 30720 bytes downloaded
[02:58:46] Initial: FB47; + 40960 bytes downloaded
[02:58:46] Initial: C727; + 51200 bytes downloaded
[02:58:47] Initial: 3959; + 61440 bytes downloaded
[02:58:47] Initial: E18D; + 71680 bytes downloaded
[02:58:47] Initial: FBC5; + 81920 bytes downloaded
[02:58:47] Initial: 7A39; + 92160 bytes downloaded
[02:58:47] Initial: 058D; + 102400 bytes downloaded
[02:58:47] Initial: A3E7; + 112640 bytes downloaded
[02:58:47] Initial: 6096; + 122880 bytes downloaded
[02:58:47] Initial: 2128; + 133120 bytes downloaded
[02:58:47] Initial: 1374; + 143360 bytes downloaded
[02:58:47] Initial: B12D; + 153600 bytes downloaded
[02:58:47] Initial: 539B; + 163840 bytes downloaded
[02:58:47] Initial: 85C3; + 174080 bytes downloaded
[02:58:47] Initial: A8E1; + 184320 bytes downloaded
[02:58:47] Initial: 0E78; + 194560 bytes downloaded
[02:58:47] Initial: 6477; + 204800 bytes downloaded
[02:58:47] Initial: 841E; + 215040 bytes downloaded
[02:58:47] Initial: 23C5; + 225280 bytes downloaded
[02:58:47] Initial: CA03; + 235520 bytes downloaded
[02:58:47] Initial: 1B65; + 245760 bytes downloaded
[02:58:47] Initial: 503A; + 256000 bytes downloaded
[02:58:47] Initial: 03CC; + 266240 bytes downloaded
[02:58:47] Initial: 9431; + 276480 bytes downloaded
[02:58:47] Initial: 0AF7; + 286720 bytes downloaded
[02:58:47] Initial: 73A8; + 296960 bytes downloaded
[02:58:47] Initial: DEDA; + 307200 bytes downloaded
[02:58:47] Initial: DB5F; + 317440 bytes downloaded
[02:58:47] Initial: B179; + 327680 bytes downloaded
[02:58:47] Initial: 9D7C; + 337920 bytes downloaded
[02:58:47] Initial: 70B0; + 348160 bytes downloaded
[02:58:47] Initial: CB0F; + 358400 bytes downloaded
[02:58:47] Initial: 7E46; + 368640 bytes downloaded
[02:58:47] Initial: A3B5; + 378880 bytes downloaded
[02:58:47] Initial: 6585; + 389120 bytes downloaded
[02:58:47] Initial: 396A; + 399360 bytes downloaded
[02:58:47] Initial: BFDA; + 409600 bytes downloaded
[02:58:47] Initial: 3CED; + 419840 bytes downloaded
[02:58:47] Initial: 7494; + 430080 bytes downloaded
[02:58:47] Initial: 752B; + 440320 bytes downloaded
[02:58:47] Initial: 19AC; + 450560 bytes downloaded
[02:58:47] Initial: 4E9D; + 460800 bytes downloaded
[02:58:47] Initial: C22D; + 471040 bytes downloaded
[02:58:47] Initial: 1287; + 481280 bytes downloaded
[02:58:47] Initial: 3203; + 491520 bytes downloaded
[02:58:47] Initial: B49B; + 501760 bytes downloaded
[02:58:47] Initial: 4104; + 512000 bytes downloaded
[02:58:47] Initial: 8DF1; + 522240 bytes downloaded
[02:58:47] Initial: DCC1; + 532480 bytes downloaded
[02:58:47] Initial: 7141; + 542720 bytes downloaded
[02:58:47] Initial: 5CF5; + 552960 bytes downloaded
[02:58:47] Initial: 4F40; + 563200 bytes downloaded
[02:58:47] Initial: 81E1; + 573440 bytes downloaded
[02:58:47] Initial: 1376; + 583680 bytes downloaded
[02:58:47] Initial: 70DF; + 593920 bytes downloaded
[02:58:47] Initial: 284C; + 604160 bytes downloaded
[02:58:47] Initial: 1D76; + 614400 bytes downloaded
[02:58:47] Initial: 775F; + 624640 bytes downloaded
[02:58:47] Initial: 422A; + 634880 bytes downloaded
[02:58:47] Initial: E836; + 645120 bytes downloaded
[02:58:47] Initial: 6E43; + 655360 bytes downloaded
[02:58:47] Initial: B979; + 665600 bytes downloaded
[02:58:47] Initial: 8530; + 675840 bytes downloaded
[02:58:47] Initial: 1FF8; + 686080 bytes downloaded
[02:58:47] Initial: 0C0C; + 696320 bytes downloaded
[02:58:47] Initial: 83B0; + 706560 bytes downloaded
[02:58:47] Initial: 6FB5; + 716800 bytes downloaded
[02:58:47] Initial: 949A; + 727040 bytes downloaded
[02:58:47] Initial: 9F7A; + 737280 bytes downloaded
[02:58:47] Initial: 13C6; + 747520 bytes downloaded
[02:58:47] Initial: 2FD0; + 757760 bytes downloaded
[02:58:47] Initial: 6BFE; + 768000 bytes downloaded
[02:58:47] Initial: 8C0F; + 778240 bytes downloaded
[02:58:47] Initial: 916D; + 788480 bytes downloaded
[02:58:47] Initial: A005; + 798720 bytes downloaded
[02:58:47] Initial: 028E; + 808960 bytes downloaded
[02:58:47] Initial: 27F6; + 819200 bytes downloaded
[02:58:47] Initial: B25A; + 829440 bytes downloaded
[02:58:47] Initial: D7FD; + 839680 bytes downloaded
[02:58:47] Initial: 96A1; + 849920 bytes downloaded
[02:58:47] Initial: B7AA; + 860160 bytes downloaded
[02:58:47] Initial: 7EE0; + 870400 bytes downloaded
[02:58:47] Initial: 23D9; + 880640 bytes downloaded
[02:58:47] Initial: 2772; + 890880 bytes downloaded
[02:58:47] Initial: 923D; + 901120 bytes downloaded
[02:58:47] Initial: 65B5; + 911360 bytes downloaded
[02:58:47] Initial: CCC0; + 921600 bytes downloaded
[02:58:47] Initial: 4E70; + 931840 bytes downloaded
[02:58:47] Initial: 4ECA; + 942080 bytes downloaded
[02:58:47] Initial: D737; + 952320 bytes downloaded
[02:58:47] Initial: 80C5; + 962560 bytes downloaded
[02:58:47] Initial: 15A4; + 972800 bytes downloaded
[02:58:47] Initial: ADB7; + 983040 bytes downloaded
[02:58:47] Initial: A2B0; + 993280 bytes downloaded
[02:58:47] Initial: 3EAC; + 1003520 bytes downloaded
[02:58:47] Initial: E831; + 1013760 bytes downloaded
[02:58:47] Initial: FF75; + 1024000 bytes downloaded
[02:58:47] Initial: BCC4; + 1034240 bytes downloaded
[02:58:47] Initial: CA0C; + 1044480 bytes downloaded
[02:58:47] Initial: D751; + 1054720 bytes downloaded
[02:58:47] Initial: EC51; + 1064960 bytes downloaded
[02:58:47] Initial: 9CC1; + 1075200 bytes downloaded
[02:58:47] Initial: 755D; + 1085440 bytes downloaded
[02:58:47] Initial: 59F8; + 1095680 bytes downloaded
[02:58:47] Initial: BF6C; + 1105920 bytes downloaded
[02:58:47] Initial: 4774; + 1116160 bytes downloaded
[02:58:47] Initial: FE4B; + 1126400 bytes downloaded
[02:58:47] Initial: CEB0; + 1136640 bytes downloaded
[02:58:47] Initial: BF2F; + 1146880 bytes downloaded
[02:58:47] Initial: BEAC; + 1157120 bytes downloaded
[02:58:47] Initial: 1251; + 1167360 bytes downloaded
[02:58:47] Initial: 4BC0; + 1177600 bytes downloaded
[02:58:47] Initial: 9648; + 1187840 bytes downloaded
[02:58:47] Initial: 1CDC; + 1198080 bytes downloaded
[02:58:47] Initial: 2821; + 1208320 bytes downloaded
[02:58:47] Initial: F0E5; + 1218560 bytes downloaded
[02:58:47] Initial: 03E1; + 1228800 bytes downloaded
[02:58:47] Initial: 1E3E; + 1239040 bytes downloaded
[02:58:47] Initial: AA8F; + 1249280 bytes downloaded
[02:58:47] Initial: C847; + 1259520 bytes downloaded
[02:58:47] Initial: A745; + 1269760 bytes downloaded
[02:58:47] Initial: 70CD; + 1280000 bytes downloaded
[02:58:47] Initial: 0339; + 1290240 bytes downloaded
[02:58:47] Initial: 239F; + 1300480 bytes downloaded
[02:58:47] Initial: 3633; + 1310720 bytes downloaded
[02:58:47] Initial: 715C; + 1320960 bytes downloaded
[02:58:47] Initial: B308; + 1331200 bytes downloaded
[02:58:47] Initial: 1199; + 1341440 bytes downloaded
[02:58:47] Initial: 7DCF; + 1351680 bytes downloaded
[02:58:47] Initial: 719D; + 1361920 bytes downloaded
[02:58:47] Initial: F8C6; + 1372160 bytes downloaded
[02:58:47] Initial: 503B; + 1382400 bytes downloaded
[02:58:47] Initial: 5F95; + 1392640 bytes downloaded
[02:58:47] Initial: 93DF; + 1402880 bytes downloaded
[02:58:47] Initial: 1E07; + 1413120 bytes downloaded
[02:58:47] Initial: 1C4B; + 1423360 bytes downloaded
[02:58:47] Initial: 6DE6; + 1433600 bytes downloaded
[02:58:47] Initial: B321; + 1443840 bytes downloaded
[02:58:47] Initial: C64F; + 1454080 bytes downloaded
[02:58:47] Initial: 69D1; + 1464320 bytes downloaded
[02:58:47] Initial: 51CA; + 1474560 bytes downloaded
[02:58:47] Initial: 8994; + 1484800 bytes downloaded
[02:58:47] Initial: 96C7; + 1495040 bytes downloaded
[02:58:47] Initial: 0EFD; + 1505280 bytes downloaded
[02:58:47] Initial: FF02; + 1515520 bytes downloaded
[02:58:47] Initial: 376F; + 1525760 bytes downloaded
[02:58:47] Initial: A151; + 1536000 bytes downloaded
[02:58:47] Initial: 813A; + 1546240 bytes downloaded
[02:58:47] Initial: B595; + 1556480 bytes downloaded
[02:58:47] Initial: 1BDB; + 1566720 bytes downloaded
[02:58:47] Initial: 2A28; + 1576960 bytes downloaded
[02:58:47] Initial: 1997; + 1587200 bytes downloaded
[02:58:47] Initial: AA47; + 1597440 bytes downloaded
[02:58:47] Initial: 1A68; + 1607680 bytes downloaded
[02:58:47] Initial: B6A4; + 1617920 bytes downloaded
[02:58:47] Initial: 555E; + 1628160 bytes downloaded
[02:58:47] Initial: C1ED; + 1638400 bytes downloaded
[02:58:47] Initial: 7CBC; + 1648640 bytes downloaded
[02:58:47] Initial: BD98; + 1658880 bytes downloaded
[02:58:47] Initial: 28F3; + 1669120 bytes downloaded
[02:58:47] Initial: 4587; + 1679360 bytes downloaded
[02:58:47] Initial: 2645; + 1689600 bytes downloaded
[02:58:47] Initial: A441; + 1699840 bytes downloaded
[02:58:47] Initial: 53E2; + 1710080 bytes downloaded
[02:58:48] Initial: 430C; + 1720320 bytes downloaded
[02:58:48] Initial: FA09; + 1730560 bytes downloaded
[02:58:48] Initial: C140; + 1740800 bytes downloaded
[02:58:48] Initial: 67D7; + 1751040 bytes downloaded
[02:58:48] Initial: 5028; + 1761280 bytes downloaded
[02:58:48] Initial: 1B33; + 1771520 bytes downloaded
[02:58:48] Initial: 75F2; + 1781760 bytes downloaded
[02:58:48] Initial: D64F; + 1792000 bytes downloaded
[02:58:48] Initial: 483D; + 1802240 bytes downloaded
[02:58:48] Initial: 2C13; + 1812480 bytes downloaded
[02:58:48] Initial: 43E1; + 1822720 bytes downloaded
[02:58:48] Initial: 2D30; + 1832960 bytes downloaded
[02:58:48] Initial: AA8A; + 1843200 bytes downloaded
[02:58:48] Initial: 4456; + 1853440 bytes downloaded
[02:58:48] Initial: 0523; + 1863680 bytes downloaded
[02:58:48] Initial: E639; + 1873920 bytes downloaded
[02:58:48] Initial: A985; + 1884160 bytes downloaded
[02:58:48] Initial: 2AD1; + 1894400 bytes downloaded
[02:58:48] Initial: 3ED9; + 1904640 bytes downloaded
[02:58:48] Initial: AC85; + 1914880 bytes downloaded
[02:58:48] Initial: 97AE; + 1925120 bytes downloaded
[02:58:48] Initial: 2936; + 1935360 bytes downloaded
[02:58:48] Initial: E147; + 1945600 bytes downloaded
[02:58:48] Initial: D38E; + 1955840 bytes downloaded
[02:58:48] Initial: DCFC; + 1966080 bytes downloaded
[02:58:48] Initial: CBE5; + 1976320 bytes downloaded
[02:58:48] Initial: 9377; + 1986560 bytes downloaded
[02:58:48] Initial: 8E96; + 1996800 bytes downloaded
[02:58:48] Initial: 5B37; + 2007040 bytes downloaded
[02:58:48] Initial: B496; + 2017280 bytes downloaded
[02:58:48] Initial: 329D; + 2027520 bytes downloaded
[02:58:48] Initial: A6DF; + 2037760 bytes downloaded
[02:58:48] Initial: 48CD; + 2048000 bytes downloaded
[02:58:48] Initial: 9976; + 2058240 bytes downloaded
[02:58:48] Initial: C763; + 2068480 bytes downloaded
[02:58:48] Initial: 391D; + 2078720 bytes downloaded
[02:58:48] Initial: 5D6E; + 2088960 bytes downloaded
[02:58:48] Initial: 06D0; + 2099200 bytes downloaded
[02:58:48] Initial: 5559; + 2109440 bytes downloaded
[02:58:48] Initial: 2135; + 2119680 bytes downloaded
[02:58:48] Initial: 4571; + 2129920 bytes downloaded
[02:58:48] Initial: 655C; + 2140160 bytes downloaded
[02:58:48] Initial: 33D3; + 2150400 bytes downloaded
[02:58:48] Initial: A251; + 2160640 bytes downloaded
[02:58:48] Initial: 0A61; + 2170880 bytes downloaded
[02:58:48] Initial: ADC5; + 2181120 bytes downloaded
[02:58:48] Initial: F636; + 2191360 bytes downloaded
[02:58:48] Initial: 1299; + 2201600 bytes downloaded
[02:58:48] Initial: C6AF; + 2211840 bytes downloaded
[02:58:48] Initial: AC63; + 2222080 bytes downloaded
[02:58:48] Initial: 815E; + 2232320 bytes downloaded
[02:58:48] Initial: FD1C; + 2242560 bytes downloaded
[02:58:48] Initial: 3509; + 2252800 bytes downloaded
[02:58:48] Initial: 4624; + 2263040 bytes downloaded
[02:58:48] Initial: 0A23; + 2273280 bytes downloaded
[02:58:48] Initial: 52D0; + 2283520 bytes downloaded
[02:58:48] Initial: 0721; + 2293760 bytes downloaded
[02:58:48] Initial: 9160; + 2304000 bytes downloaded
[02:58:48] Initial: 2342; + 2314240 bytes downloaded
[02:58:48] Initial: 6AB8; + 2324480 bytes downloaded
[02:58:48] Initial: D2CB; + 2334720 bytes downloaded
[02:58:48] Initial: FF0F; + 2344960 bytes downloaded
[02:58:48] Initial: 1301; + 2355200 bytes downloaded
[02:58:48] Initial: 2C98; + 2365440 bytes downloaded
[02:58:48] Initial: 251C; + 2375680 bytes downloaded
[02:58:48] Initial: D3EA; + 2385920 bytes downloaded
[02:58:48] Initial: 6A9A; + 2396160 bytes downloaded
[02:58:48] Initial: 5CD3; + 2406400 bytes downloaded
[02:58:48] Initial: 7E55; + 2416640 bytes downloaded
[02:58:48] Initial: 03A5; + 2426880 bytes downloaded
[02:58:48] Initial: 7CA9; + 2437120 bytes downloaded
[02:58:48] Initial: 3EA3; + 2447360 bytes downloaded
[02:58:48] Initial: 44AC; + 2457600 bytes downloaded
[02:58:48] Initial: 4E9A; + 2467840 bytes downloaded
[02:58:48] Initial: 9E43; + 2478080 bytes downloaded
[02:58:48] Initial: 5A57; + 2488320 bytes downloaded
[02:58:48] Initial: 2425; + 2498560 bytes downloaded
[02:58:48] Initial: D602; + 2508800 bytes downloaded
[02:58:48] Initial: 5AAD; + 2519040 bytes downloaded
[02:58:48] Initial: 4142; + 2529280 bytes downloaded
[02:58:48] Initial: 2C77; + 2539520 bytes downloaded
[02:58:48] Initial: 9279; + 2549760 bytes downloaded
[02:58:48] Initial: 11E3; + 2560000 bytes downloaded
[02:58:48] Initial: 2C8E; + 2570240 bytes downloaded
[02:58:48] Initial: 598D; + 2580480 bytes downloaded
[02:58:48] Initial: 8E47; + 2590720 bytes downloaded
[02:58:48] Initial: B10D; + 2600960 bytes downloaded
[02:58:48] Initial: 09D0; + 2611200 bytes downloaded
[02:58:48] Initial: F417; + 2621440 bytes downloaded
[02:58:48] Initial: 92E6; + 2631680 bytes downloaded
[02:58:48] Initial: 795D; + 2641920 bytes downloaded
[02:58:48] Initial: 2EEE; + 2652160 bytes downloaded
[02:58:48] Initial: BA3B; + 2662400 bytes downloaded
[02:58:48] Initial: 0404; + 2672640 bytes downloaded
[02:58:48] Initial: 4809; + 2682880 bytes downloaded
[02:58:48] Initial: 4BE5; + 2693120 bytes downloaded
[02:58:48] Initial: A3BF; + 2703360 bytes downloaded
[02:58:48] Initial: 3ABE; + 2711113 bytes downloaded
[02:58:48] Verifying core Core_a3.fah...
[02:58:48] Signature is VALID
[02:58:48]
[02:58:48] Trying to unzip core FahCore_a3.exe
[02:58:49] Decompressed FahCore_a3.exe (9325056 bytes) successfully
[02:58:54] + Core successfully engaged
[02:58:59]
[02:58:59] + Processing work unit
[02:58:59] Core required: FahCore_a3.exe
[02:58:59] Core found.
[02:58:59] Working on queue slot 01 [October 27 02:58:59 UTC]
[02:58:59] + Working ...
[02:58:59] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 4 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 3816 -version 630'
[02:58:59]
[02:58:59] *------------------------------*
[02:58:59] Folding@Home Gromacs SMP Core
[02:58:59] Version 2.22 (Mar 12, 2010)
[02:58:59]
[02:58:59] Preparing to commence simulation
[02:58:59] - Assembly optimizations manually forced on.
[02:58:59] - Not checking prior termination.
[02:58:59] - Expanded 763389 -> 1404481 (decompressed 183.9 percent)
[02:58:59] Called DecompressByteArray: compressed_data_size=763389 data_size=1404481, decompressed_data_size=1404481 diff=0
[02:58:59] - Digital signature verified
[02:58:59]
[02:58:59] Project: 6701 (Run 10, Clone 9, Gen 70)
[02:58:59]
[02:58:59] Assembly optimizations on if available.
[02:58:59] Entering M.D.
[03:00:38] Completed 0 out of 2000000 steps (0%)
[03:39:04] Killing all core threads
[03:39:04] Could not get process id information. Please kill core process manually
Folding@Home Client Shutdown at user request.
[03:39:04] ***** Got a SIGTERM signal (2)
Folding@Home Client Shutdown.
The only suggestion I can give you is to try setting up the SMP client normally and see if that works for you.
That was a general suggestion to everyone with this problem. It wasn't addressed to you specifically ;).
sounds to me like its having issues writing to the files, probably a permissions issue. maybe try running the program in admin mode.
It's a good guess. I would also suggest trying to install the smp client manually in case the software didn't do it correctly.
To make up for the potential drop in PPD because of this... just installed the CPU client and GPU client on my laptop.
T6400
9300GS
So far so good :D
Have you tried deleting the tracker and redownloading it. I had a problem with the tracker and it fixed the problem and havent had one since
