Mr. Tibbetts: “I won’t be surprised if in 10 years there’s no evidence of cancer from these towers[...]
I don't really understand the actual point of 5G, it seems to be hopelessly flawed by the use of super high frequencies and their lack of distance travelled and nearly complete requirement to have line of site and good weather. Maybe I'm wrong but that's what I've read about it so far, and it really seems like the technology is going to cost these companies a shitload of money to install in cities, and anywhere that isn't urban is going to have sporadic coverage or no coverage at all in terms of 5g. They have to have 5g antennas facing in multiple directions on nearly have street pole... High speeds are pointless if you only get them in certain super specific conditions.
That said, I have no fucking clue what they are on about in terms of aesthetics. You mean that telephone pole that always looked like shit, somehow looks shittier with some fancy antennas on top of it? Give me a fucking break.
Can anyone paste the article here? It's being blocked for some reason.
5G is going to do wonders for IoT. Edge computing is only growing, so its a necessity.
This made me giigle.
One of the first things i noticed moving to the states was
1: lack of bicycles
2: phone poles
We don have phone poles anymore in my birth country ( or they are really rare) as they are all burried down... well the cables not the poles.
But this kinda reminded me of the first time i was in the states
I'll believe it when I see it. Just because your device is IoT doesn't mean it is immune to the immutable laws of physics as regards high frequency EM waves.
There is a clear misunderstanding in 5g. 5g millimeter waves is not the same 5g that will be used by your cell phones and other devices. So for cell devices you will have it running on lower mhz band just like LTE signal. But it will be much faster and lower latency. But it will be slower than what they are achieving with millimeter waves.
In other words. NOT ALL 5G is the same. What you are referring to is millimeter waves that have short length and require line of sight and shit.
I am very filliar with this, but the lower frequency band (pretty much the same frequencies as current cellular bands) had a much more modest bandwidth increase.
In tests thus far it has been limited to only 15%-50% over LTE Advanced, and usually towards the lower end of that range.
At best 5g Will be a marginal speed increase, not the revolution the industry is claiming.
All of the hype is based on the upper hand which is in the millimeter wave range, and will never be practically useful outside of a very few corner cases.
What if the wave does not identify as high frequency?I'll believe it when I see it. Just because your device is IoT doesn't mean it is immune to the immutable laws of physics as regards high frequency EM waves.
Companies are not going to spend billions on tech if its worthless. I assure you of that. There are endless applications for 5g, its not just all about millimeter waves and weather limitations.
Why? When it has the same range and throughput as WiFi for near locations, and the same range and throughput as LTE for far locations, what's the big benefit that makes 5G a silver bullet for IoT? It doesn't really bring anything new to the table.
Companies can get wrapped up in hype just the same as people.
Here's just one example that cost $165B
That seems more like a (software) optimization done at the protocol level. Less handshaking, less overhead. If that's the case, then that could be implemented with existing hardware.I remember reading somewhere that one of the big benefits of 5g was the massive changes to the underlying network protocols that govern it. Something about doing away with the Ack Nak process and greatly decreasing overhead. Especially in busy or contested areas.
Famous last words.
I just can't buy into the hype.
Can be if the existing hardware has the CPU to handle increased processing. But the new antenna’s seem really cool, far smaller, use less energy closer to the source so again less energy could mean better battery life for devices. There are lots of neat advantages to 5G that 4G and it’s hardware could never touch.That seems more like a (software) optimization done at the protocol level. Less handshaking, less overhead. If that's the case, then that could be implemented with existing hardware.
Yeah, when I lived back to the U.S. after growing up in Sweden I was shocked by all the ugly poles and the wires hanging from them. I never saw these in Sweden. Everything was under ground.
It really ruins ones views.
Yeah, when I moved back to the U.S. after growing up in Sweden I was shocked by all the ugly poles and the wires hanging from them. I never saw these in Sweden. Everything was under ground.
In many areas, it depends on when the neighborhood was built out. My old place was built in 1942 and everything electrical was above ground. Water, sewer and gas were underground. Many neighborhoods built in the 70s and after had things underground. Moving things underground is often discussed in OK but the expense would be high as most backyards are fenced, have out buildings, trees and such on the easements. Plus getting all of the utility owners to play well together would be difficult. Imagine having to run three sets of wires/fibers while avoiding existing sewer, gas and water lines, many of which need their own repairs.
Oddly, in the older neighborhoods, 5G rollout may be easier. Hard to imagine that a few more boxes with wires coming out the bottom will be that much of an vision blight. And the squirrels will like the new chewing opportunities. The neighborhoods where everything is underground may well have a good argument against a pole, box and wire display every hundred yards or so.
I know of a colleague that live near me and is affected by these cell towers. He would get massive headaches sometimes if he is in close proximity working on a job. At home, he wired his whole house and has wifi turned off. Buys special low end smart phones from Europe to alleviate problems.
So yeah, I'm all for the NIMBY sentiment. Especially when I drive pass a few towers (one by the freeway entrance close to where I live) on my way to work as pointed out by him that I'm totally oblivious about. The less exposure to it, the better.
I wouldn't be so dismissive of it as I'm seeing it with my eyes and I'm very thankful that it only affects a very small segment of population. It is the reason why it's so easy to say it is something else. Or as another colleague likes to jokingly say in a good natured way, "probably just in his head". Since I've seen it with my own eyes, I believe it. I wouldn't have otherwise as I've never even heard of such a thing before encountering him.Yeah. The symptoms people who claim to suffer from EHS (electromagnetic hypersensitivity) are real. Studies have confirmed this. The problem is with the "E" part. Several high end double blinded studies have confirmed that there is no relationship to EM radiation. These people are definitely suffering from something, but there is no way in hell EM radiation has anything what so ever to do with it.
Yep. Your sentiment is pretty common including me these days. "As long as it doesn't affect me, it's not a problem." Or "If it costs money, it's not a problem."How soon do we start hearing about antifa tearing down 5g towers and burning installation equipment ?
I wouldn't outright dismiss it.
Different frequencies cause different effects... One study found that cellphones and wifi users reported headaches, while another found that lower frequencies applied to different part of the body had positive effects. Length of exposure likely plays a part, as would signal strength.
EM radiation has been shown to have cellular level effects, that alone says there is more to this. Stick a cockroach in a microwave, and set it for 10 seconds. Tell me that electromagnetic radiations' effects are "no way in hell" having any effect...
