Chipset, G33 vs P35?
dennisjai
which chipset is better folks?
I know G33 is newer, but performance/overclocking wise, is the G33 any good?
I had a G31 board, it was able to handle good FSB but had poor bios and no PCIE lock. Going to vary heavily board to board. Just have to find the board you want and read up on it.
G33 chipset
Gigabyte GA-G33M-DSR2, very good overclocker, 450 fsb+
Asus P5K VM, good overclocker, 400 fsb+
For moderate overclocking either will do pretty well.
Just make sure to flash to the latest bios available for either board to ensure compatibility with the newer CPUs.
I don't think you can go wrong with either chipset. If you need onboard video or mATX, go with the G33. It depends more on the board than the chipset as they are both good chipsets.
G33 is just a P35 with the addition of GMA 3100 graphics. I would go for the P35 if you do not need integrated graphics as it will overclock better due to the lack of extra heat produced by the integrated graphics.
