revenant
[H]F Squad Captain
- Apr 10, 2005
Greetz peepz... El Rolio and I are starting this joint work log to cover our new water cooling projects, both to be done on Lian-Li v1000s! The project really started back in May of this year when we started PMing each other with messages like this:
I'm still not sure what he meant by "the swimming chick" (lol) but the basic idea was to use the reference Nvidia 6800 Ultra heat sink with a gpu water block for maximum independent cooling of the memory on air with the gpu cooled on water... yes!!
So Roli took my idea to hit ebay, but to email the sellers with NV Silencer modded 6800 Ultras to sell us their unusued reference design heat sinks... he scored three of them and I ended up with two of those:
and actually put them on my GTs for the time being
w00t..
So ... the plan was to get our water cooling plans together by end of summer / star of fall... well, that time approacheth! and we're both gearing up for the project again... Here's how I started my end of this:
I ended up selling about $200 worth of goods on the BuySellTrade forums (here) and made used that money to fund the purchase of all of my water blocks!! I decided to go all DangerDen after thinking about a switech cpu block for a while...
The TDX first (from pharmd24), then the Maze4 (from nicepun), and the other lo-pro Maze4 directly from DangerDen... I am also waiting to get a thermaltake flow meter... all these have 3/8s fittings to go along with the Koolance PC3-725BK which I am going to buy next week! (http://www.xoxide.com/koolance-pc3-725bk-case.html no tax for me). Yes - I know it's expensive, and I know it's not the top of the line performer, but it's a good performer, and it's classy as hell, and quiet. Plus with some upgrades I have a feeling I will be able to get this thing to perform greatly. (koolance upgrades on pumps and rads are now available)... I suppose I can upgrade the fans also... la la... anyways...I plan on modding it a bit, so there will be more than just "ok, I put the tubes on, filled it, and turned it on... yay". lol... I promise!! anyways, I love the look of this v1000 exos II combo... so damn sexy...
Anyways... that's all I have for now.. I'll take some more shots of my block tewnight.... then start with the work log posts when I get back from vaca on Sept 12th.. hopefully my case will be sitting on the door step when I get home!
Roli - you can take it from here if you like
el rolio said:
"what i was talkin about is you kno the original ref design o nthe 6800gt? those l shaped black pinned ramsinks? like the gpu would be independent with the swimming chick and then a l shaped cooler on the ram. well i have seen pics... oh wait the sheild is back on....
ok ads again. so ive seen pics of WC setups wehre the gfx card has like a maze black for instance and then that l-shape for the ram, satifying the water to gpu... ram separate concept. and plsu i agre with what some of the hard gawds was sayin in the OC/water section of the board that its ridiculoous to be payin $120 or supn for those blocks that cover everything. looks damn cool, low profile and all, but its half the price i paid for the card, 75% of the entire WC setup. thats bad bizness baby.
i was lookin at that cooler by the way (the vantec) in a store yesterday... but i measure the neo2 chipset cooler and was like 10 mm, not the 20mm i thought it would be which most others are, and the NB on the neo2 is RIGHT UNDER the 6800... not much clearance."
w00t..
