Cheap and small build?
xellos2099alpha
A friend of mine ask me to help him put together a machine that is small like s shuttle, quirt and cheap, like around 400-500 for case, mobo, processor, ram, I think of the following parts.
Case:APEVIA X-QPACK-BK/420 Black Aluminum 1.0 w/ ABS plastic front panel MicroATX
79.99
Desktop Computer Case ATX 420W power supply Power Supply
http://www.newegg.com/Product/Produc...82E16811144161
processor and mobo:
Phenom™ II X6 1055T
A785G3 AM3 mATX
$180.00
http://www.microcenter.com/specials/...ndlePROMO.html
Graphic: He don't game much on pc sp intergate is fine
Ram: Avexir 2 gig ddr 3
http://www.mwave.com/mwave/SKUSearch...emory%20module
or Microcenter a data 4 gig ddr for 49.99
Getting that Apevia case+PSU combo would be a pretty fucked-up thing to do to your friend considering the shitty quality of Apevia PSUs:
Apevia ATX-AS500W-BL
Apevia Warlock Power 900W
XQPack's Included 420W PSU
Aspire Beast 680W Power Supply
So grab this copy of the Apevia case for a lower price:
$60 - Black Chiefmax FC-DV21M mATX Case
And get this PSU as well:
$50 - Antec NEO ECO 400C 400W PSU
It'll only be $15 more than that Apevia X-Qpack once shipping is factored in but you get a significantly better quality PSU for your friend.
I'm curious as to why you went with the X6 1055T and not one of the X4 quads. What will your friend be using this system for?
I consider the x6 since I know he use photoshot quite a bit and x6 really benefit that.
I think of 2 build, one is fast and cheap, pther is small and quiet.
Fast and cheap
My original build with a better psu and change it to phenom II x4
Small and quiet
Intel Core i3-530 Clarkdale 2.93GHz 119
Gigabyte GA-H55N-USB3 $105
ADATA 4GB DDR3 $50.00
APEX MI-100 $55
Dvd drive 30-50.
APEX MI-100 $55
Dvd drive 30-50.
Definitely small but overpriced, hotter, and lower quality (Another case with a crappy PSU)
Advice for improvement? Here is revised small and quiet
Lian Li Q07 65
Antec Earthwatts Green 430W $30 AR
Lian Li Q07 65
If you don't want a normal DVD drive (internal), or are willing to use a laptop (slim) DVD drive, then may you consider the SG05 or SG06?
Either comes with a decent power supply unit, that is easily capable of powering most mITX setups, and is rather small...
Though the setup you have now is decent :)
