My main router (router 1) is a D-Link DIR-880L which is cat5 cable connected to my router2, a Linksys E1200. The Linksys (router2) is bridged using the same SSID and password so as to extend my wireless signal. The Cat5 cable connection between the routers is LAN to LAN. This setup works fine, no problems.
I would like to change the SSID for both routers. No problem with router1, but I how do I change the SSID on router2?
Is there a method other than re-setting router2 to factory defaults and then re-configuring as a bridging router?
