CEC Drafts Regulations for Power Usage in PC Components
Armenius
Extremely [H]
California Energy Commission’s Proposed Regulations on Personal Computers Poses Threat to Prebuilt Gaming Desktops and Gaming Monitors | Delidded Tech
The California Energy Commission has drafted regulations to govern the power usage of whole systems and the components they use that could shake the hardware market. There will be a "high expendability" exception for hardware that require more power to perform, such as those used in gaming or CAD machines. A couple interesting sections:
Video Cards
To be classified as “high-expandability” without meeting the minimum score of 690, a system must attain a minimum level of frame-buffer bandwidth(memory bandwidth on the graphics adapter). The proposed level is 400 GB/s by 2018, and 600 GB/s by 2020. In addition, the system must use a power supply of 600 watts or greater.
The level of frame-buffer bandwidth required is significantly higher than what is offered in high end graphics adapters today. For example the NVIDIA GTX 1080, which has a MSRP of $600, has a memory bandwidth of just 320 GB/S. This falls 20% short of the requirement slated to go into effect by 2018.
This is an extremely ineffective metric, because memory bandwidth is generally not the main factor that contributes to GPU idle power consumption. In many cases, the necessary memory bandwidth in modern GPUs has gone down due to improvements in memory compression technology.
By the above definition, the only "consumer" video cards meeting this bandwidth requirement currently are the Fury X, Fury (both with HBM), and Titan X (Pascal). The article makes a good point about compression techniques being used to reduce needed bandwidth, making the bandwidth requirement and its "forward-looking" metric ineffective.
On HBM:
HBM(High Bandwidth Memory) is an upcoming standard that will provide substantially increased memory bandwidth while consuming significantly less power, with the drawback of currently being very expensive. Obviously, the way in which the system’s drivers interact with the hardware to determine clock speed, power saving states, as well as the architecture of the GPU itself are the most important aspects of idle power consumption, but these are the types of factors that the CEC is seeking to improve through regulation.
Using HBM is the obvious workaround, but it will significantly increase production costs, and that cost will be passed on to the consumer. Yields with HBM2 are also still an issue.
Power Supplies
For a power supply to qualify for the exemption, its combined output must be at least 600W and be 80-Plus Gold Certified.
Most desktops will have limitations imposed on power consumption that gaming computers cannot realistically meet- however, “high expandability” systems won’t be subject to these power limitations. Instead, they’ll be subject to a different set of limitations designed for workstations, such as requiring a power supply that meets the 80 PLUS GOLD standard.
A likely effect would be for system manufacturers to include unnecessary pieces of hardware in order to boost the expandability score of their system into higher ranges. This will increase costs while providing little benefit and less choices to the consumer. If the systems do meet the high-expandability metric, there’s still the costs associated with requiring a 80 PLUS GOLD power supply as well as the cost of testing and meeting regulations.
Computer Monitors
A dynamic equation based on the physical size and pixel resolution will be used to determine what the power limits are. An exemption is being considered for displays with a pixel resolution of 8.2 MP or higher, which would mean 4K and above. OLED, high-refresh, and curved monitors are also being considered for exemption.
Here are the formulas:
I think most monitors meet the sleep and off requirements. But according to this equation, a 27" 2560x1440 monitor like mine would be allowed a maximum of around 40W in operation. According to TFT Central, the PG278Q uses a little more than 51W at 100% brightness, and is manufacturer specified for up to 90W.
I haven't delved into the regulations themselves, yet, but I am quite interested to know how they came up with this curve. I think it would be quite difficult to reach for those displays larger than 30". The Dell P4317Q shows operational power consumption of 160W. Using the above formulae, the same monitor would be limited to around 85W, which is less power allowed than if it were a 1440p monitor.
Direct Sources
Energy Commission Proposes Energy Savings for Computers and Monitors - Proposed standards could save consumers millions
http://docketpublic.energy.ca.gov/P...ency_Rulemaking_Docket_Number_16AAER02Sta.pdf
Don't you love how the governor's press release says "could save consumers millions?"
Reminder that this is only in the proposal stages currently. And also keep in mind that PC hardware are not like cars; i.e. I don't think manufacturers are going to make versions of their hardware just for California.
That's the dumbest thing I have ever read lol (And I am a green type guy). Nothing there will save anyone anything. Just pay out their nose and get inferior junk for fast replacement.
It goes all wrong when someone essentially tries to save the world in one go and skip every step on the way. From crawling to running without learning how to walk.
Also a note from the pdf, the single and only place to save power is on the desktop (90%). And they expect to reduce that with something like 40% in average. Welcome back to 15-17" monitors? The standard office PC is something like a power efficient i3 using IGP and a single HD/SSD. What else is there to get that kind of reduction from. In other words, you have to buy OLED/QLED. And we all know how the OLED screens today only comes with a 14$ premium over the LED in size 27"+ and 2/4K.... :p
40$ savings over 5 years on a desktop. But they expect you to only pay 14$ more. So 26$ saved over 5 years or roughly 5$ a year.
Wow. How much time was wasted trying to come up with this nonsense? All pc component manufacturers are pushing for higher efficiency already, what's the point of this? Some people seem to do the work just to keep a job they have instead of actually doing something useful.
California was offended that they found a market segment that was unregulated so they rectified the problem.
California is a huge failed socialism experiment. The state is broke and if they can find anyone they can squeeze tax dollars out of to prop up themselves, they're going to do it regardless if it's good for the people or not.
Amazing how bureaucrats will regulate anything they can wrap their claws around. I would make those selfsame bureaucrats, and their families, have to live under their own rules for five years before they can be imposed on the public. And, they would have to work, successfully, in that industry for five years before they could propose any regulation.
Just saying, since the 5 gallon gas can vapor nozzle has been such a fiasco.
San Andreas fault was put there as a fail safe....
Who forgot their monthly bribe to their local CA politician? Who was left out of the graft circle this month? Did AMD or nVidia miss a payment? Is Intel no longer contributing? Who's fingers weren't greased this month? Who?
Also:
"[...]the component requirements and power management settings are consistent with the ENERGY STAR® 6.1 voluntary standards[...]"
This is very typical of CA. Taking a "voluntary" standard and making it mandatory, at gunpoint.
Useful stuff done checklist:
Evil monopolistic Intel - ~2x better perf/actual TDP for Skylake over SB.
Regulators regulating for the greater good -
I don't know, this proposal doesn't seem overly restrictive since they have a bunch of exceptions for high performance gaming computers, workstations, and 27"+ monitors. If anything, it seems like it could have the end effect of lowering prices of some currently overpriced high-performance technology by forcing sooner mass production, so these tech companies don't lose access to the California market.
And it's not like requiring all Californians buy a high-quality power supply for their high-end gaming computer would be such a bad thing, since who doesn't do that anyway? For typical buying habits for people on [H], I don't see this having any negative effect at all. It feels like it's more targeted towards the mainstream consumer market and businesses.
According to IT now 10 percent of world's electricity consumption, report finds - IT accounts for 10% of global energy usage.
Cloud ;)
But I doubt its 10%. That would have to be everything in the "entertainment" category.
10% could perhaps be reached in a high efficiency home without electric heat, including water or AC.
We live in a high efficiency home with district heating and water heating, and we got 4 PCs. And 2 of them being gaming PCs. And we are not reaching 10%.
