Hey all,
A quick update -- I revised the first page and the webpage to show the timing moved out to early Nov for production kickoff.
While I'm waiting for the samples to be built, it might be a good time to verify I have everyone's correct contact information (for the 61 pre-orders so far).
I believe I have replied to everyone who has signed up on the pre-order form. You should have received a confirmation email from me within a few days after you placed your pre-order.
I only got 1 bounce back for an invalid email addy (a David B from Sweden), so if you are David B from Sweden or not sure you received my confirmation, please go ahead and send me a PM.
I'll check into it and make sure everything is peachy.
Thanks
Looks great.
I have one complaint, nothing to do with the product...
You keep changing the name of the thread and it confuses me everytime i click on the alert. XD. Keep maybe the first couple words the same at least?!
I am curious if anything is gained by facing the PSU fan upward so it can help exhaust heat from the case.
Yeah, I have never seen my SF450 fan run. I just ran a thermal test with a wattmeter and I'm only pulling a max of 270W with a i7-6700K and Gigabyte GTX1070.I have both a Corsair SF600 and 450 and the fans don't actually run often enough to be put into any kind of cooling equation.
Sorry about that. Maybe it was the pop up blocker, since a paypal window is supposed to pop up.Just ordered. Had to use Edge because neither the Checkout nor the PayPal button worked in Chrome. I have ad blocker and popup blocker installed, so that might be the reason.
Is there enough room to swap out the fan on the Shuriken to a more quieter or powerfull one?
I believe you should be able to swap the Noctua NF-A12x15 PWM fan for the stock model...?
Looking at the graphs the Shuriken 2 gets better temperatures than the noctua cooler. So would you recommend it over the NH-L9x65? Is there enough room to swap out the fan on the Shuriken to a more quieter or powerfull one?
Love the pics and the stats, and can't wait to get my own Case! Nice Work!!!
Can't use a 25mm fan because it would be too tall for the case but any 120X15mm would work. I plan on using this one with the Big Shuriken, https://www.newegg.com/Product/Product.aspx?Item=9SIA85V6DP5026 140mm but it has 120mm mounting holes.
As I said in my other post, there are also some 120x20 fans. I looked at the NH-L9x65-Clearance-Graphic on page 1. Between the fan and the case there is a 3mm gap. The Shuriken being 58mm tall, without fan 46mm, compared to the Noctuas 65mm, you could fit an 20mm thick fan onto the heatsink. The question is if the gained cooling performance at a lower speed and therefore lower volume - if there even is such an advantage - would interfere with the lower clearance towards the side panel...
First Edition Batch Update --
Orders are up to 27 as of mid day today Tues Nov 28. So we are getting close to reaching or exceeding the 30 case kick off min threshold (!!)
2 1/2 days left to order so if you are on the fence, you still have some time. I am pretty much updating the webpage daily with more photos and such, so if you need more convincing or just info you might check it out. But feel free to ask me any questions here or there.
Thanks!
Fire
