pendragon1
Extremely [H]
- Oct 7, 2000
finish looks good! but wheres the beige?!
Man I'm waiting on Silver or White or even Space Grey, but heck I'll take beige =P.finish looks good! but wheres the beige?!
Took about 45 minutes to move everything from the old case (Lian Li PC-A05B) to the MI-6.
https://photos.app.goo.gl/c4LcXCovM47nHf8x1
https://photos.app.goo.gl/LEChTqcdfHCrUhvq2
https://photos.app.goo.gl/bi0QOigYS1eIoZAr2
https://photos.app.goo.gl/UWd2wP2wUXqs50xz2
Gigabyte Z170N-WIFI
Core i7-6700 w/ stock Intel cooler
Intel 600p 512GB M.2 SSD
Crucial Ballistix Sport LT 32GB DDR4-2400
EVGA GeForce GTX 1060 Gaming
Corsair SF450
Noctua NF-A9x14
Everything went together pretty easy. I only had one issue which was after I removed the front I/O board to install the Noctua fan. When I re-installed it, I found that 2 out of the 3 standoffs were either cross-threaded or had some debris in the threads. I worked at it a while before I got the screws to go in easily.
Really love how all of the different screws are individually bagged and labelled with exactly what they're for. Very nice touch there.
Note that due to the location of the USB3 header on this particular motherboard, I cannot fit a larger CPU cooler and still have USB3 on the front-panel unless I get an extender cable.
Gigabyte Z170N-WIFI
Corsair SF450
Noctua NF-A9x14
Build looks great, thanks for sharing some pics. I had that same motherboard previously in my Ncase, that usb 3.0 header is in a terrible location. Trying to plug it in with my Dark Rock TF was no simple job.
Yeah, might be tough to fit a big cooler over the USB3.0 header cable that will stick out of the MB. Maybe asome sort of 90 deg adapter?
I did a quick search and found 2 Z170's that have that USB header location near the CPU: Giga G1 Gaming GA-Z170N-Gaming, and Giga GA-Z170N-WIFI.
I also found 3 270's: EVGA Z270 Stinger, Giga GA-Z270N-WIFI, Giga GA-H270N-WIFI.
For those MBs an extension will likely be needed.
Maybe Gigabyte is coming to their senses, --I noticed that their Z270N-Gaming 5 has the header back along the edge where the 24-pin is.
Well I did find this 90 deg adapter over at ebay.
Nice find, I searched all over the place for one of those about a year ago and couldn't find one. Would have been perfect for my Z170.
Thanks for all the hard work, Fire! It's was really cool to watch your project progress from start to finish and to actually be able to buy the final product.
BTW, this case is for my 13-year-old son and he is really happy with it, too. He has two friends for which I have built very similar computers for in the past year in a Rajintek Metis Plus. He had them come over to show them the same components in the MI-6 which is almost exactly half the size.
I'm still waiting for a black powder coat cover sample, but I did get a white powder coat sample cover today.
It is a 80% gloss level. I installed the white cover and mated it to a black top plate.
I am supposed to get the black powder coated cover Monday, and I'll post it when I get it.
Right now, both black and white will be the powder coat options.
Fire
Gigabyte Z170N-WIFI
Corsair SF450
Noctua NF-A9x14
Brian,
I just realized that you can use a standard Corsair front I/O board assy. It's $9.99 on the Corsair website (http://www.corsair.com/en-us/carbide-series-air-240-front-i-o-panel). The front I/O on the MI-6 has exactly the same layout as the Corsair. The differences are:
The Corsair has much longer cables.
The board is longer to include a HDD LED and a reset switch, but you can cut that end of the board off if you like (that is what I did with my prototyping).
The Corsair USB jacks are 2mm shorter, so they would be recessed in the front the 2mm.
HERE is a side-by-side of the MI-6 board and a Corsair one I used for prototyping.
EDIT-- This is all to get a longer usb cable to reach his mb 19pin header...
Brian,
I received a sample cover and top plate, and some small sample pieces today with black powder coat. It is a matte, low texture coating.
It is pretty flat but has a slight texture and color variation depending on the lighting angle. I'm thinking to do this for the next production run.
I'm going to offer it to those still waiting for their MI-6, if they prefer it over the brushed black anodized cover that are being remade now.
Fire
pics still aint working. just drag and drop them into the [H] window, no need for hosting sites.I installed the powdercoat cover and top plate on a case ........
Ok, I modified my last 2 posts with pics to just direct attach the files.pics still aint working. just drag and drop them into the [H] window, no need for hosting sites.
I wish I bought this case when I was in the waiting list would u be doing a second batch after you're finished with the first one or is it final?
Hello everyone,
I received my MI-6 a week ago and thought I could share my build in it.
Specs:
Here are some pics (sorry about the messy "cable-management" )
- Biostar X370GTN
- Ryzen 7 1700 @ 3.7 GHz
- 32 GB G.Skill RipJaws V @ 2933 MHz, CL 16-18-18-38
- Gigabyte GTX 1080 Mini ITX 8 G
- 525 GB Crucial MX300 M.2 SSD
- 2 TB Seagate 5400 rpm HDD
- 800W Silverstone SX800-LTI SFX-L PSU
View attachment 59549 View attachment 59550 View attachment 59552
View attachment 59554 View attachment 59551 View attachment 59556
The MI-6 compared to my old ATX-Case
View attachment 59557 View attachment 59559
The MI-6 on my desk
View attachment 59560 View attachment 59561
Building in the MI-6:
Thanks to the instructions on the backside of the "owner certificate" I was able to fit everything without big issues into the case.
A tipp from me for future builds in the case would be to detach the mounting of the riser cable, than fit your GPU onto it, than reatach everything back in the case. I had trouble fitting my GTX 1080 without removing the mounting.
One thing that literally came up was my PSU. At first, it didn't seem to fit with the fan facing down, the mounting holes were 0.5 mm too low for the screws to fit. The other way around, I could've fixed the PSU in the case, but that way it would suck in the warm air from the CPU and GPU.
As it turns out, I just had to remove the 120 mm fan grill that was a little bulky and so pushed the PSU up. Now, the PSU is fitting with its fan facing down, like it was in my old case.
View attachment 59553 View attachment 59555
One very positiv thing about the MI-6 is that the motherboard-panel snapped right into its mounting hole. My other cases I had till then pushed the metal plate out every two seconds, and I had to hold it in while mounting the mainboard. So, thumbs up for that .
No, but seriously, building my PC in the MI-6 was fun and straigh forward, and seeing all my hardware cramped into so little space is very cool.
Temps and Noise:
Due to the Wraith Spire from the 1700, I am not able to fit the metal outer shell onto the case, and it's currently in a kind of "open bench"-state of build.
(My first idea for cooling was supposed to be a little surprise: I wanted to fit the Asetek 545LC in the place of the 92 mm bottom fan. I kinda "macgyvered" a video from Linus Tech Tips, and measured the pixels of a screenshot, so I could evaluate wether the 92 mm radiator would fit into the fan mount with its tubes attached to one side or not. To my own luck, I figured out that, only with a SFX-PSU, wich I don't have, there was enough room for the bottom fan. Maybe one of you would like to try this ridiculous idea?)
CPU-temps were quiet the same as before, with idling temps around 47 °C, but never exceeding 50/52 °C during gaming. During benchmarks or video-encoding using handbrake, the temps rose up to around 70 °C, but that was also the maximum all around.
The GTX 1080 reached 72 °C during 30 min of Valley-Benchmark (recorded video of that run was unfortunately corrupted, so I can't upload the evidence), during gaming it lies between 55 to sometimes 84 °C.
The noise level is expected for this kind of specific hardware. The loudest component is probably the GPU, with its 92 mm fan spinning up audibly under stress. Because of that, I can't really tell if I could hear the CPU or PSU fan, but they should be much quieter, especially the PSU one. The next noisy component is the HDD, but that might be because it is sitting right in the front of the case, facing directly towards me. But with the metal shell sitting on the case, the noise could be a little bit more damped, with likely higher temps. But I can't test that now.
Also, the noise level doesn't bother me as much, because I usually listen to music or gaming audio over headphones. Anyway, I will maybe change out the gpu fan for a stronger and quieter one from Noctua or another company, so I am more on the safer side.
What comes next:
The very next step would be to either get custom and much shorter PSU cables, or to buy a new CPU-cooler, so I can fit the metal case around the rest of the MI-6.
After that, I am thinking if I should upgrade to an 1800x (or the next gen Ryzen) or to an 8700K due to its much higher clock speed. Either way, I should change out my mainboard, as it seems to be a little unstable from time to time (it has only one 12 V CPU power connection too ...)
Again, a big "Thank You!" to Fred for creating and selling this awesome case .
And I look forward to see your builds in the MI-6.
