C2D multiplier question
stetser
I've done some researching, and I cannot seem to find a definite answer to this question:
I'm going to be purchasing a DFI 965-s Dark and a 6320 or 6420, depending on one thing: will I be able to lower the multiplier if I purchase a 6420? I know I can't raise it, but I'm only interested in lowering it.
It depends on the bios. I would imagine that lowering it shouldn't be a problem, but you might have to wait for a bios that allows it.
The DFI P965-S does allow you to unlock lower multipliers. So you could run your E6420 at 7x if you wanted...
Here's something I have been wondering...how come a bios cannot unlock the higher multipliers for a chip?
hardware locked in the cpu. c2's allow lowering to as low as 6x because of speed step.
Thanks for letting me know, I figured it had to be hardware locked. Didn't know about speed step either, but I looked it up, thanks.
