Built-in Office
Status
Not open for further replies.
jen4950 said:
Got any links on this kind of stuff?
Just google for fiber-optic lighting. The technology has been around for a long time, and they tend to use Halogen light sources for the intense central light. Of course, now that LEDs are increasing in strength and capability, there are systems out there that are LED-driven too. (Some pretty spiffy RGB systems, too).
Fiber can be had in a few varieties with the two major ones being sidelight and endlight. Sidelight fiber emits light omnidirectionally from its sides; they contain minor imperfections designed to scatter light instead of to retain it. Endlight fibers are near-perfect and contain no imperfections, allowing the light to bounce its way along inside the fiber until it comes out the end.
You could trim the whole desk in sidelight fiber and hook it up to an RGB LED driver and be able to accent your desk in any color you can imagine. :D
Crikies. You have the grain going Vertical on the big doors and horizontal on the small.
The staing looks good. Did you mention what wood this was.
wow, i cant wait till i grow up and get my own house lol, if i ever build a house, i would use nothing but that lighting, thats insane. I bet it uses a LOT less power and lasts a LOT longer :) but thats just a guess
jen4950 said:
Fightin' Texas Aggies!
From one Aggie ('91) to another: Whoop!
Desk is looking good. Are you planning any power distribution methods, like long power stips?
Keith
I'm not that picky.. It'll be stained dark enough where it won't be all that noticable, and it was a helluva lot easier putting it together with one sheet for the back.
ezkill said:
good work, but why couldn't you design it with wood that isn't so thick. I doubt sheets of wood half the size would break no matter what you put on them. But anyways, good work.
Strength is not everything; stiffness, i.e. deflections are a big issue with any material you use. And I don't want cracks in my finish like on my other desk for one. Another reason is I am countersinking all of the screws and bolts- well, if you countersink 1/4" into 1/2" material you will have the fasteners pull thru- especially with the small finish screws I am using.
[edit] Why the 1/4" countersink? if a countersink is too shallow, the wood filler does not have enough wood to grab onto and can fall out. Hell- that doesn't make sense! It'll just stick to the screw! Well- no, it won't. What happens is a pocket of air gets trapped (no matter how small) in the socket, and very few things stick to coated screws anyway. So what you rely on is the wood grain on the sides of the hole to retain the filler once it hardens. (analogy to piles in foundations: you have two different effects- end bearing and skin friction. The end of the pile doesn't stick to the dirt or rock, so only skin friction is considered when the pile has uplift, or tension. So long story short, be sure to countersink your holes enough for the wood filler to grab the side of the hole. :D (engineer for ya')[/edit]
Another reason, I'm putting a fascia on all plywood edges, so if I use anything less than 3/4" ply, I'll either get splitting along the plywood planes, or I'll miss the plywood when screwing into it.
Finally, especially when building it, I'm walking all over the thing and I have a bunch of overhangs (cantilevers), so I don't want to step on a corner, break it off or crack it, and have to go three steps backwards to replace it.
As for the framing, I'm using 2x material to avoid splitting with the large bolts, or fasteners in general for that matter. I'm sure some of you have screwed a screw into a 1x4 and had it split right down the middle. Again, I'm walking all over the thing and don't want splits or collapse during construction.
I'm using the large bolts as I said before to be able to have a large enough face on the bolt to where I can either with a hammer or wood filler, lodge it in place in a blind hole and keep it from spinning (and then cover it with an oak veneer). Analogy is try to turn a coke can in your hand versus a pencil; it's alot easier to hold the coke can still.
And finally, I'm using douglas fir and pine for the frame; plywood with an oak veneer for the large surfaces, and oak hardwood for the finished surfaces.
Keith
That's the real cool part- keep watching. It'll be pretty cool.
Here are some of the parts I have in mind:
[BLANK]APC Website is down.. will fill in later.[/BLANK]
New Pics:
Top shelves installed; inadvertent plug for 409.
Frame for bottom shelf.
HOT DAMN! Almost like I planned for that to happen!! :D
somebody has probably already said this but oh well, Good thing you are building it in the room it's going to stay in otherwise you would have to knock down a wall to move it in :eek:
or you could have read the thread and found out that it's being beuilt precisely to be able to be taken out of the room it's in. he's building it in modules that can be easily unbolted.
Very nice work. I like how you have allotted space for hot air to leave via fans on the underside. That's my kind of feature!
from one geer to another geer.....
nice, very nice......
BTW Nice tools as well, sorry to not see more DeWalt though... ;(
jen4950 said:
Wrong rant- read again-
100% Male heterosexual. Actively seeking companionship from available hot and smart ladies :D
jen are my initials- jen4950 was assigned to me by A&M in 1998- it stuck.
ooooooooooooooooooo fuck.... my bad :eek: sorry about that bro :D
/runs away crying....
(kids, thats why you never assume things on the internet)
TSS Modder said:
yea, but i think in that case, it was more of just Me, and none of You. :p
That's the general rule- I could really give half a shit about you calling me a girl.. it's the intarweb :D
(just trying to drink my beer and build my desk- everything else is narrative.. :D )
One of each for sure:
http://apc.com/resource/include/techspec_index.cfm?base_sku=SU3000RMXL3U
http://apc.com/resource/include/techspec_index.cfm?base_sku=SU48R3XLBP
http://apc.com/resource/include/techspec_index.cfm?base_sku=AP9551 - all of the bullshit
http://apc.com/resource/include/techspec_index.cfm?base_sku=AP9560 - 2 x rest of computer equipment.
I've had alot of good experience with APC; they'll get more of my business.
jen4950 said:
I have a couple rack mounted APC units here at work for my remote closets.. They have been going strong. Of course, for the main computer room, I have a 21 KVa Best Power unit. That thing has 10 car battery sized batteries in it.
Keith
Devilish grin.. I bought myself a present today.. :D
Figured, I need a Happy Easter Present from me to me.. :D Obviously had to use it the second I got it put together.. The sucker weighs 250 pounds! :eek: (156 kilos)
So I am thinking some simple shelves above my monitors and desk.. Trying to get creative.. I am really liking the light overhang/canopy thing, so I think I am going to do that over my desk with some lights etc. But I don't want it as imposing, I want it to appear light and efficient.
So I am playing around with something like this:
Comments?
BTW- the top one was cut with a jig saw, and the bottom two were cut with my new band saw..
Your saw bears a Sierpinski fractal so it's cool with me. (No, Zelda fans, it's not the Triforce :p)
edit:I guess f a n b 0 y s is a forbidden word.
Actually it's a trademarked logo- but rock on.. :D
It's coming along great. Keep us posted through the Easter weekend. I love large scale wood work projects. I have seen those clamps before. Which ones are they? The ones with trigger squeese adjustment.
Right now I am wrapping up one of these:
Once I am finished I am looking to start this:
woodstore_1838_1074222
I am sure I can relax in either of those. My apologies if this is considered a thread hijack. I thought it pertinant about and awesome wood project like jen4950's.
I really need to learn some woodworking skills and buy some tools. People can do amazing things. It makes me envious.
http://www.scrollsaw.com/sf29.jpg[/MG]
[IMG]http://us.st8.yimg.com/store1.yimg.com/I/woodstore_1838_1074222[/MG]
I am sure I can relax in either of those. My apologies if this is considered a thread hijack. I thought it pertinant about and awesome wood project like jen4950's.[/QUOTE]
ANNOUNCEMENT!!
Don't worry about hijack's - I love seeing other peoples work!
The second one is a Morris Chair and they are VERY VERY comfortable! I know, because I have some that I built. I built them because the ones I found in stores were not sized right for me. So I made a big one. The one in my TV room has a cup indentation that I routered into the chair arms towards the end, holds a pop can perfect. I really need to get a camera. :(
Keep up the good work Jen4950
Been busy with my new band saw..
Parts for my idea of the day..
Idea of the day shaping up..
More to come after dinner. :D
Basically, I needed a place to hide the wires for the lighting I will have supported by this shelving system..
i look at this thread for the first time cuz it was popular and i love all those pic i wish i could make all the nice stuff!!
When i grow i wanna be a engineer and ur my hero yay lol :p
................expect from the drinking
Dude- Alcohol is great in moderation; even better in excess! :D
Status
