building new desktop
kyro, I moved this thread to our General Hardware section, you'll probably get some better responses here. Also, there's a list of questions you could answer that can be very helpful for folks to assist you with evaluating the build, you can find them here: http://hardforum.com/showthread.php?t=1349433
There may be some room for improvement, but that should be a great machine. :)
I would consider trying to go cheaper on the case and shifting that to your GPU budget instead. The CM 690 II for instance could net you $40 extra moving you up to a HD 6870 at least.
im thinking of changing the mobo to the msi p67a-gd65
i heard its a good board and read read reviews on it
i want to get a full tower because of wiring n stuff
suggestions anybody?
We can't make any suggestions till you answer those questions that Oldie linked to.
So please do so.
mainly for gaming and web browsing
around 1000
3) Where do you live?
philadelphia area
mainly the mobo and tower
None, im using a laptop atm
6) Will you be overclocking?
yes
plan to have a 21-23'' size i think i want to spend 140 max on this because i already have a hdtv in my room
Soon like within the month or so
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
im thinking of either the asus p8p67-m pro or msi p67a-gd65
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
nope
i live close to the microcenter and im planning on picking up the i5 2500k from there
i realized that there are two different hd 6850 one from sapphire and other from xfx whats the difference?
So you need CPU, mobo, RAM, GPU, HDD, DVD burner, case, PSU, HSF, and OS correct? Monitor as well? All of that part of the $1000 budget?
Please answer the question correctly please.
nope
So is the cost of Windows 7 part of that $1000 budget?
XFX has a lifetime warranty and better customer support than Sapphire. Sapphire is cheaper.
idk what to look for in a mobo really but basically i want it to last for at least 2-3years
os is not part of the budget hoping to bootleg it somehow if not ill buy the oem
Ok that really doesn't help narrow down which mobo you should get. Any decent mobo will last 2-3 years. Considering that you cannot figure out what features to look for, then go for the Asus as you have not provided any good reason or justification for the higher costs of the MSI mobo.
Two things:
- Don't be a bloody cheapskate: Buy the OEM OS.
- Any more discussion of bootlegging an OS is not allowed here on the forums.
Also, please answer my first question in the previous post.
CPU, mobo, RAM, GPU, HDD, DVD burner, case, PSU, HSF, moniter are all part of the budget.
So everything below has to be part of the $1000 budget? Do shipping and taxes have to be included as well?
Case, Power Supply, Processor, Motherboard, Memory (RAM), Hard Drive, DVD burner, Video Card, Operating System (Windows), Monitor
Do you also need a new set of speakers or keyboard/mouse?
I don't know if this has been asked, but I think you chose a mATX board and one of the largest full tower ATX cases on the market?
EDIT: ah, you are also looking at the MSI ATX board, okay :)
Assuming shipping isn't a factor and adding another $100 to the budget to cover Windows 7:
$190 - Intel Core i5-2500K CPU from MC (tax already included)
$158 - Asus P8P67-M PRO Intel P67 mATX Motherboard
$41 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
$210 - XFX HD-687A-ZNFC Radeon HD 6870 1GB PCI-E Video Card
$160 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive + Windows 7 Home Premium 64bit OEM
$26 - LG GH22NS50 DVD Burner
$110 - Acer S201HLbd Black 20" DVI Widescreen LCD Monitor
$30 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
$80 - Antec Truepower New TP-650 650W PSU
$80 - Lian Li Lancool PC-K58W ATX Case
Total: $1085 plus shipping
I included the OS since you're gonna have to buy it anyway.
