HardForumer
- Oct 1, 2011
Are you saying that because of the reviews? If yes not that they're not from Amazon.ca, totally different warehouse and staff.
EDIT: Nevermind!
EDIT: Nevermind!
Supposedly yes to both. However I don't recommend Sapphire at all.So back to the 6050 to 6970 topic.
The Toxic is the one that is actually faster than a 6970 when unlocked right?
But once unlocked, will it be able to overclock just as good as a stock 6970?
Safety VS Performance.
Does it really increase performance?
I also found this:That'll be fine.
Yes. Overkill but yes.Will 2 of those play any game maxed out at 1920x1200 and good AA at a good FPS?
Well both sides have pros and cons. However, Nvidia has just as much driver issues as AMD. However, traditionally, Nvidia's SLI tech has had better scaling and drivers and AMD's Crossfire tech. But in the past year, AMD's Crossfire tech has improved dramatically to the point where they're viable against SLI. However, Nvidia SLI tends to have faster performance on day one releases of games whereas it takes a week to a month for AMD Crossfire to catch up with driver releases. The larger VRAM found on most AMD cards tends offer better performance in the long run.Also, I've been reading on some sites that Crossfire has lots of driver issues that NVidia doesn't. Is that another reason so go with 570s/580s instead of 6950s/6970s?
Although I think 1280MB of memory on the 570s aren't going to be enough since people are using up to 1.4GB on BT3 at 1920x1200...
So you're saying that on Metro 2033 for example, I'll get above 40 FPS on highest settings and good AA at 1920x1200 on a single 6950?
Nice.
So now I'm back to that HD6970 Vs. GTX570 dilemma.
Although with AMD you get the advantage of getting an HD6950 and unlocking it, basically paying $100 less for a 6970 so that makes the choice easier... but still not easy...
Or will the two GPU ram join and make it 2.5GB in total with 2 1280MB 570s?
Ok so that means the GTX570s with only 1280MB will likely be a problem with BF3 right?No, they each use their own VRAM.
Maybe. That was just a beta. We dunno for sure if those VRAM reportings were actually solid.Ok so that means the GTX570s with only 1280MB will likely be a problem with BF3 right?
I guess I can wait 15 more days for reports on the final game but from what I know the final game could be even more demanding due to them not making highest settings available on the beta. Could go either way.Maybe. That was just a beta. We dunno for sure if those VRAM reportings were actually solid.
So if I'm going to buy 2 for a RAID 0 or 1 setup I should get the R version?
Anything needed other than 2 hard drives to setup a RAID mode? any cables that connect the two?
