SylarPowers
- Apr 9, 2009
I'm starting this build log for fun (not build help). I'm going to build the very best PC I can - then teach it morals so it doesn't become the next Skynet and nuke us all. My John Henry. I was going to build a budget system, but I had trouble living with that, so I decided what I really needed was a crowbar to pry my wallet open! So I am allowing 3 thousand US dollars to morph into liquid metal and reform into a "Tight" PC Rig. Come with me if you want to live.
If you don't get the Terminator Sara Chronicles references, we can't be friends. I'm truly sorry. Lucky for us that does not preclude becoming forum buddies. So to start with I already ordered some great parts for John Henry:
Dell 2009WA Display ($220 Delivered - Dell)
http://www.engadget.com/2009/01/15/dells-2209wa-lcd-monitor-reviewed-deemed-king-of-22-inchers/
http://www.cnet.com.au/dell-2209wa-339294389.htm
This E-IPS LCD is fantastic, IPS technology for hundreds less than normal. At 22" widescreen it lacks the size/resolution of a 24" display, there's no 1:1 ratios to be found here, but it is a steal for the money. This will allow me to spend more in other areas and to see into John Henry's soul.
Silverstone TJ10 Nvidia Edition Chassis ($330 Delivered - Amazon)
http://www.silverstonetek.com/products/TJ10-WNV.php
http://www.3dgameman.com/content/view/10628/103/
Best chassis out there IMHO. Stylish metal with Nvidia artwork, 5 green LED fans, unique high end mid-port cooling, removable motherboard tray, high mod potential (everything unscrews apart easy). A solid aluminum foundation - John Henry needs high grade metal.
After redonkulous research at CDFreaks, Sony Optiarc 24x Sata DVD Burner ($30 Delivered - Newegg)
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16827118030
Best burner and ripper out there bar none. NEC Chipset. Now I can back up John Henry's source code.
Arctic Silver 5 Thermal Compound ($10 Delivered - Newegg)
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16835100007
Keeps John Henry "cool". His future so bright, he's gotta wear shades.
Cat-6 50ft Ethernet Cable ($10 Delivered - Newegg)
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16812189038
Cheaper and faster than Wi-Fi, let's John Henry jack into The Matrix.
Will post more once I receive "intelligence" from the future, but I call it intel for short. PSU choice is now imminent. The shortlist includes the Antec Signature 850w and the Enermax Revolution 85+ 850w/950w/1050w PSU's.
