rabidz7
- Jul 24, 2014
Gaming and encoding
$2000 is the maximum, but cheaper is always better. Tax and shipping is included in the budget.
Cincinnati, Ohio. I have Microcenter access
CPUs, motherboard, second PSU, watercooling pump, blocks for the GPUs, another CPU block, tubes, additional radiators if needed, maybe some more RAM.
I will be reusing a 900D, one EK CPU block, 4 8GB DDR3 sticks, a SeaSonic 520W Platinum, two 980 Classifieds, a 480mm radiator.
6) Will you be overclocking?
Yes, heavily.
It is a CRT, so... It doesn't exactly have a "max resolution". I usually use 1600x1200 at 100Hz or 2304x1728 at 70Hz. I do plan to upgrade to a FW900 soon for 1920x1200@96Hz or 2560x1600 at 72Hz.
Within 1-2 months.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
No special features, but SLI is needed.
I have valid disks for 64-bit Windows 10 and 8.1.
The only other criterion for this build is that it must use two 16-core AMD chips (I do lots of encoding and dispise Intel, plus I think having two CPUs would be cool). Also, please stay away from Asus parts as they have poor warranty service. I was looking at the 1200W SeaSonic Platinum PSU and Supermicro boards.
Gaming and encoding
Yes, heavily.
Within 1-2 months.
