engiNURD
- Jul 17, 2006
That EA430 is more than enough power for your planned rig, and its a good quality PSU, too.
Build the rig today, it posted on first try. Windows corrupted from my old IDE hard drives, something about hal.dll, and I cant reinstall it w/o a Sata CD Drive. Do you guys have any recommendations?
I'm pretty sure my mobo (EP45-UD3P) has 2 device max for IDE, and I have 2 IDE hard drives. Should I try disconnecting my slave HD and connecting my CD Drive in order to reinstall windows?Yeah that's why we never recommend moving an existing OS install to a new system. Shit like that happens.
Anyway, if you have a IDE CD drive, just connect it to the same IDE cable, Might be a performance loss but at least it'll get your system up and running
Alternatively, buy a SATA CD drive.
Thanks for the feedback, saved me from wasting money on LightScribe. I decided to just buy this Sata drive and install XP that way instead of fumbling around with IDE devices. Hopefully just a repair will do the trick. My IDE hard drives are both 60 GB and 7200 RPM, I hope that wont bottleneck me.No, lightscribe is not worth an extra $5 if you won't ever use it; and to use it, you need lightscribe disks.
Plug one in, and hope the XP setup detects your old XP installation. If not, try the other one. If neither disks yield a previous version of XP installation being detected by XP Setup, then get a new HDD if you don't want to erase either of the drives. How old are these IDE drives? You can't really enjoy your new system if it has slow HDDs, btw.
Even if it already posted successfully?YES, you NEED to carefully remove everything and install those standoffs. If you tried to power the system on with no standoffs, the board may have been fried.
Thanks for the heads up, looks like my freaking out was warranted. I'll definitely install them before booting up again. Can I screw the standoffs into my case with just my fingers?the brass pegs are an absolute necessity. you will seriously fuck your system up without them. it will only be a matter of time before something grounds and cooks your components.
That makes sense, not sure what I was thinking, just don't trust myself with any decisions anymore. Will reseat it and plug in the new sata cd drive I ordered thats supposed to arrive tommorow and update on my progress. I can also upload pics if requested.the screws that go with the pegs are the ones that can completely thread into the pegs.
Not if you don't use it. Paying for something because it was cheap but never using it doesn't make it worth anything.Lightscribe is easily worth the extra $5 bucks!
No lables to fuck with or trying to read shitty ass hand writing on the discs...Lightscribe discs are but mere pocket change more then standard discs...
That's what I was alluding to when I said pics will come later. I'm still doing some airflow tweaks, don't want it photographed till its done and prettyno hardware pics?!
nice build. I am thinking of doing the same build. I have one question I have a Samsung syncmaster 204B. I think it will only support 1900x1200, which is more than enough for me. My question is should I go for 4850 or 4870? I need to save where I can, but dont want to be disappointed for 40 bucks. Also I just purchased A Corsiar 550 watt psu. I was thinking of maybe going with a 260gtx, but they have high power requirments. This psu wont handle a 260 will iT?
Thanks for all the help enginurd, you helped me from day 1 all the way through the end, I really appreciate it.Good temps, great voltage... you can probably still go higher without any longevity risks, and I re-enabled EIST & C1E after I found my stable OC... saves on power consumption, so you don't feel like you're wasting all that power (or just run Fold@Home instead and make use of that processing power, lol).
Sorry to revive an old thread, but as predicted by you guys, my HDD's are bottlenecking me. What do you guys think about the WD6400AAKS going at Newegg for $60 right now? Is there a real-life performance drop for 16mb buffer compared to 32mb?
