Harlequin76
- Sep 22, 2011
Hello,
After the faulty question I decided to recheck my build components fail rate, most of them seem ok,the h80 is a bit on the bad side ,but its not that pricey so I can live with replacing.
1) Gaming, Photoshop,multitasking,web browsing
2) 1500 dollars without tax.
3) Europe
4) I wrote my build down.
5) No
6) Yes, the cpu
7) 23" the dell ultrasharp u2311h(if there is better please suggest)
8) next week I buy the stuff already got the items reserved
9) High level motherboard such as the Gene-z has everything i could ask for.
10) no, I am thinking or to buy windows 7 pro , or home
thanks!
anyway here it is: (P.S i dont like AMD at all)
Case: FT03
PSU: Seasonic X660 modular
Motherboard: Asus Maximus IV Gene-Z
GPU: Asus GTX 570 Dcuii
CPU: Intel i5 2500k
CPU Cooler: Corsair H80
Memory: Corsair Vengeance 1600mhz cl9 8gb (the red one with heat spreaders)
SSD: OCZ 120gb vertex 3 (changing to crucial m4 128)
HDD: Samsung f3 1TB 7200rpm
Fans: Akasa Apache 120mm x4 (2 instead of the silverstone angled fans, and 2 instead of the corsair stock).
Monitor: Dell Ultrasharp u2311h 23"
Mouse,Keyboard,Pad,Extras: I am going for mostly roccat, I think(keyboard not sure)
The computer fits my budget, I don't want Extreme power ,but rather good power and good temps, and low noise(as much as possible at least. I am planning to OC my CPU ( any ideas how far I should go? or I just test it slowly and go up till satisfied?)
Anyway, any thoughts?( I am already super close to buying these items,already reserved them in the store)
Thanks!
Harlequin76
3) Europe
5) No
6) Yes, the cpu
thanks!
Case: FT03
CPU: Intel i5 2500k
Thanks!
Harlequin76
