orangezero
- Jan 4, 2003
I haven't built a computer in a while and after some nights of reading I've come up with the following:
Q6700
Gigabyte GA-EP45-UD3L
4GB (2x2GB)
I've read the 6700 and EP45-UD3L are pretty decent overclockers and the prices seems good if you can find them in stock. Q6700 runs slightly hotter than the newer Q9xxx, but also may overclock a bit better? I do not need raid, sli or crossfire so I think that board would work good. As a bonus it is on the list for hackintosh boards which I may experiment with at some point in the future.
After that I am less sure:
4gb (2gb x 2) Not sure what I need to not limit my overclocking, without breaking the bank. I think I should be searching for ddr2 1066 with some heatspreaders: OCZ? Kingstonhyper? I've seen some sets around $45-65 that have decent reviews. Are timings that important for overclocking? It seems I can spend a lot more money to maybe get a 1-3% increase, which is not what I'm going for at all. Also, I'm not so sure I'd need more than 4gb at this point since I mainly use XP and 32bit ubuntu. And, I can always add more later. 2x1GB seems too low at this point.
Graphics: probably go a few generations back, 9800 or 9600 nvidia maybe. Can't remember right now who has better linux support. Both of my older cards seemed to work fine in Ubuntu and mint. Probably won't game much, but might use this as an excuse to start again.
PSU: What do I need for the above, without being excessive? I will probably only have one or two hard drives, and maybe a dvd drive. Is 700w like the OCZ silentxstream too much? Could I get by with a quality 550 with enough on the 12V rails? What is enough?
Heatsink: Not sure, saw the Arctic Freezer pro 7, but I seems to run loud. Scythe are good? Any to avoid?
Already have the case, drives, etc. Might spring for a 30gb SSD drive, but I'm not sure if it would be a ton better than a 74gb 1st gen raptor in normal everyday tasks.
My goal is to get the Q6700 to over 3ghz without much effort, and perhaps to 3.2-3.5 if possible. I'm not as concerned with upgrading in the future, and i7s are out of my price range for now. I've always gone amd, but want a intel quad for some reason.
Thanks for any insight.
Q6700
4GB (2x2GB)
