Squirreljester
- Jan 27, 2011
Half of you have AMD's in your sigs for your desktops, why is that when someone says they are thinking of buying one you say its a bad idea?
Yes. Though how old is your True Power Trio?Also, if I get a 6 core 125watt proc, will my Antec 650watt PSU be enough still?
Hey now I may be sb amd fan boy, but I admit the sandybridge chips are a better value for the money. I have recommended them to everyone with the budget.Yes. Though how old is your True Power Trio?
That's not the reason. Besides a few self-avowed fanboys *cough bastage cough*D), we tend to recommend parts based on their price to performance ratio, the user's location, the budget for the system, and the needs of the user.
So in your case, since you live near a Microcenter, then your best bet would be one of those AMD Phenom II X6 combos or one of the Phenom II X4 combos. If you were not near a Microcenter, then your best bet would have been the Core i5 750 if within budget or the Phenom II 955 Black Edition if costs savings were needed.
True true.Hey now I may be sb amd fan boy, but I admit the sandybridge chips are a better value for the money. I have recommended them to everyone with the budget.
Yes. The i5 750 is stil faster than the 955 even at stock speeds. So yes once you start overclocking, the performance difference is even greater.so what is better/faster 955 @ 3.2 or the 750 @ 2.66? gaming wise. I am also not a big fan of OCing unless I can OC my CPU and not my memory & I like to OC on stock voltage
From what ive read is the even tho the i5 750 is at 2.66ghz & the 955 is at 3.2 the i5 750 will keep up with the 955 & sometimes surpass it. So overclocking the i5 750 would be the best option? Im asking for myself cause im building my rig this frida7 & its either the 955 or the i5 750. I cant wait for sandy
That doesn't sound right: the Trios haven't been sold since 2008 IIRC. You absolutely sure that you have Antec Truepower Trio 650W?And the Trio is about a year old.
They also have 8GB of corsair memory for the same price as the 8GB of value G.Skill.
http://www.microcenter.com/single_product_results.phtml?product_id=0347304
As bastage said, a good majority of the times, you're better off with a single faster card.1 question about crossfire, can I get 2 lower priced cards, run them in crossfire, and have them perform better than a single expensive card?
In most vases your better off with a single faster card
Is the i5-750 faster than the 1090T black edition?Yes. The i5 750 is stil faster than the 955 even at stock speeds. So yes once you start overclocking, the performance difference is even greater.
Yup, eBay. Still brand new when I bought it though.That doesn't sound right: the Trios haven't been sold since 2008 IIRC. You absolutely sure that you have Antec Truepower Trio 650W?
How are rebates not guaranteed, they are listed in the price. It's kinda odd for a company to risk a lawsuit over $20.$95 isn't the same as $80. Oh around here, we don't ever factor in rebates. They're not guaranteed.
You're replying mobile?!Vases - swype failure for cases
Yes. The i5-760 is slightly faster than the i5-750, but it's more widely available and, in certain areas, around the same price as the i5-750Is the i5-750 faster than the 1090T black edition?
Microcenter has an i5-760, still Lynnfield, still clocked at a stock 2.8, so what's the difference?
Since you're not going with a high-end video card, it will work with your setup. But I would recommend a new power supply should you ever go for a newer, better video card soon. (You should definitely replace it with your next complete system build, as you are using two-year old technology.)Yup, eBay. Still brand new when I bought it though.
I opened up the case and looked at the PSU myself to get the model number because I couldn't remember what it was exactly.
There has been many instances of a manufacturer not honoring a rebate even when the person submitting the rebate did everything correctly. Plus, you're waiting weeks for the rebate check/card to arrive, which does you no good if you have to keep everything under a strict budget.How are rebates not guaranteed, they are listed in the price. It's kinda odd for a company to risk a lawsuit over $20.
Wonderful thing, huh?You're replying mobile?!
Understandable, I'll probably pick up a 750watt PSU with this build, because I decided last night to use my current setup as a media center machine, so I'll stick it's guts into a mini-tower case, or one of those neat receiver looking cases, stick XP media center edition on it (or LinuxMCE, although I didn't have a good experience with this the last time I played with it), and put it out by my TV which has a VGA port on it.Since you're not going with a high-end video card, it will work with your setup. But I would recommend a new power supply should you ever go for a newer, better video card soon. (You should definitely replace it with your next complete system build, as you are using two-year old technology.)
I've never run into one, but I understand the waiting part, as most of those rebates are 6 to 8 weeks.There has been many instances of a manufacturer not honoring a rebate even when the person submitting the rebate did everything correctly. Plus, you're waiting weeks for the rebate check/card to arrive, which does you no good if you have to keep everything under a strict budget.
Nice hehe, they should make a HardOCP droid app.Yea I normally do from my phone during the day while at work.. Keeps me entertained while smoking out in the cold.
Yeah it's true: Sometimes sheer improvement in clock speed performance is enough to overtake any advantage in multiple cores. Since games don't scale past four cores these days, the extra two cores of a hex-core CPU doesn't help much unless you have multiple apps running in the background. Even then, the sheer clock speed performance of a CPU can negate that advantage somewhat. So yes the Core i5 750/760 is faster than the 1090T in games.I can't imagine a 4 core proc being faster than a 6 core proc
I've never seen or heard of that.Although I did read that the OC'ing of the AMD procs are only dynamic, and it only OC's half of the cores, but that also keeps the proc temps lower too.
I recommend these 750W PSUs:Understandable, I'll probably pick up a 750watt PSU with this build
@Danny I was reading this review http://www.guru3d.com/article/phenom-ii-x6-1055t-1090t-review/ and on page 3 the reviewer was talking about the hex-core only OC'ing half it's cores... unless this is a quirk of the hex-cores, or I read it wrong.
And doesn't any board that has 2 16x slots pretty much support crossfire? Or does it specifically have to state that the motherboard supports crossfire?
Just out of curiosity, why aren't the Intel motherboards ever suggested? I see a lot of them that have some pretty nice specs, for pretty much the same price point as ASUS, Gigabyte, MSI, etc.
Posted via Mobile Device
@4LC4PON3 I'm gonna go with the i5-760 and that ASUS P7P55D-E board. The only differences I can see between that board and the PRO version of it is the PRO has crossfire (8x/8x), the sound card has a coax out, and it has one more 3GB/s SATA port, none of which I will ever really need.
