Squirreljester
- Jan 27, 2011
My current computer is a P4 2.8Ghz HT socket 478 on a P4P800S motherboard, a Radeon HD 3850 AGP video card, in an 8 bay tower I've had for probably 10 years.... so I think it's about time to do a full upgrade.
I do have a 5 year old 17" LCD that I would like to upgrade as well.
Moderate gaming (I play DAOC on a semi-regular basis), web browsing, iTunes, web flash games (for the kid), light Photoshop and very light video editing. I usually have like 10 tabs open on my web browser, iTunes open, and a couple other programs open at one. Also, the one twist is I would like to run a VM of XP so I can play some of my really old games like Baulder's Gate and Warcraft II.
$700 - $900 is ideal, but I'm getting the 12 month financing from NewEgg so it can run closer to the $800 mark.
3) Where do you live?
Illinois, right outside of Chicago, USA.
Proc/motherboard, ram, video card, LCD monitor (as an option, I can forgo this item for better components and just pick up a monitor from Best Buy), case, everything but the PSU as I just replaced my old 350watt about a year ago with an Antec True Power Trio TP3-650 650W.
Antec True Power Trio TP3-650 PSU and my 1.5TB SATA II drive I bought 3 months ago.
6) Will you be overclocking?
Possibly, I'd like to since it's so easy now, and it's much more stable than back in the day. I've read a lot on the ability to OC on air cooling, if I bump up to an i5-2500S or K will I need one of the $30 coolers NewEgg has? Also, is the arctic silver compound good to get or is the white goo that comes with the processor ok?
I have an old 17" LCD, I'd like to pick up a 22" widescreen, but I can buy one from Best Buy if giving up the monitor will get me better build components.
Before January 31st to get the NewEgg financing and deals.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
I want a couple SATA 6GB/s ports, a couple USB 3.0 ports, at least 6 USB 2.0 ports, I don't need crossfire as I will be just running a single video card, at least 16GB of ram capacity, dual core at the very minimum but I would like to go i5-2500S or K quad core, I need to be able to burn CD's, DVD's, DL DVD's, and BLU-RAY in the future), and integrated sound is fine. I don't plan on upgrading for quite a few years. I actually wouldn't mind an SSD drive for my OS if there's any way to make a slight cut somewhere else in the build, as this would give me much better performance when running a VM.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I'll need a copy of Windows 7 64-bit PROFESSIONAL (I need remote connection host capabilities). I have legit copies of Windows XP Pro for the VM I'd like to run.
I've spent a couple days researching this stuff, and I've build a minimal cart on NewEgg already. Here is what I've built:
LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM $17.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
COOLER MASTER Centurion 5 CAC-T05-UB Black /Blue Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case $48.98 $6 (instant off)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119047
ASUS VW224T Black 22" 5ms Widescreen LCD Monitor $149.99 ($20 instant off)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236078
MSI N430GT-MD1GD3 OC/TF GeForce GT 430 (Fermi) 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Low Profile Video Card $83.99 ($10 MiR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127535
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBRH $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276
ASRock P67 PRO3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard Item #: N82E16813157222 $123.99 ($15 instant off)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157222
Intel Core i3-560 Clarkdale 3.33GHz LGA 1156 73W Dual-Core Desktop Processor BX80616I3560 Item #: N82E16819115068 $149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115068
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM Item #: N82E16832116758 $139.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116758
Total is $769.91 with $21 shipping.
Thanks for any help and/or advice you can give.
