Bought wrong Kingston HyperX Ram
Zukker
I posted earlier about using Kingston HyperX Fury and HyperX DDR3 memory together. I thought I had bought another 2x4GB of identical Kingston HyperX black to match what I have in my computer. I actually bought Kingston HyperX Genesis. Same number except the Genesis model has an X at the end and I missed that.
The main difference is the HyperX is 9-9-9-24-33 while the Genesis is 8-8-8-24-35. I have both sets installed and ran Intel burn test (passed at 5 x) and have player BF3 with no issues. Computer seems stable and runs just fine.
The overall settings according to CPU-Z is 9-9-9-27 which is at the lower settings which I am okay with.
Will there be any major problems with running these two sets of 8GB ram?
Thanks in advance!
No issues with this whatsoever as long as:
1) it's running at the lower RAM speed OR it's running stably at the higher RAM speed
2) you are okay with it
I've ran mismatched RAM before in a C2Q system, 3 RAM slots with a 1GB stick each, and 1 with a 2GB stick with different timings without issues
I don't see it as a problem. Make sure the same style sticks are in the same channel.
Ive run different brands and timings before, no problems.
One matched set in channel A and the other in channel B.....:D
The issue with mismatched ram is usually failure to boot and crashes, so if your computer is running stable then just be happy about it imho.
