Boot priority concern
KuJaX
I have a friend that asked for my opinion and I am not sure on the answer so figured I would post it here.
His hard drive in his computer is a SATA WD hard drive running Windows XP. He said he has had it for several months and everything has been perfectly fine. Recently however, every once in a while he gets a "reboot and select proper boot device" when he turns his computer on. He said the only way around it is by unplugging the computer for a few minutes and trying to turn it on multiple times.
I told him to run Western Digitals diagnostic program and he said the extended test as well as the quick test both passed.
What could be causing the problem? Is his motherboard or SATA controller on the motherboard going bad? Could the SATA cable be bad itself or the port on the motherboard?
could just be that his cmos battery is bad.. but tell him the next time it happens to go in and check the boot order and see if its correct.. then have him unplug it and turn it back on and see if its exactly the same..
Strange, he said that this time it shows "Disk Read Error occured". He said he unplugged the power for a few minutes, plugged in and then it booted properly.
Can he get a CMOS battery at like Radio Shack or does he have to contact his motherboard manufacturer for one? How often do the batteries go out?
CR2032, about once every... 9-10 years.
I asked him and he said that his system is about a year old.
He also ran the western digital data lifeguard diagnostics utility and extended test was pass.
Maybe a bad cable or one that isn't fully connected. I would have occasional boot issues like that, and it turned out the cable was dislodged slightly. Not enough to be a problem all the time, but just enough to cause some issues.
