DeathPrincess
- May 15, 2010
I need a third opinion, because the first two (mine and a toshiba repair place) vary wildly. Someone I know had a broken laptop (broken DC jack). And as I hate soldering and doing anything with a laptops (theres no laptop ATXtype standard thing) and I have long nails damnit. It was sent in and came back all shiny new.
For a week.
(a week) Later I was asked to look at it because of BSODing. It was a faulty RAM module. (this might be important). So I took out the 1gb stick and ran memory tests, and they all came back fine. When I finished up with the second memcheck on the single chip it switched off. I checked the light indicators and neither the power or battery icons were showing, even with the power plugged in. So I thought they must have left something unplugged inside. Dissasemble, check connections, nothing. Wont turn on, low battery signal flashes.
So as it has been a week since its been back, so I called the repair place. Apparently its not their fault. I phone toshiba who says it is. Toshiba phones them, they agree to do it under warranty. Send it back in.
But now according to them using a power supply with the wrong voltage (the one that came with it) has blown the motherboard. I dont remember seeing any blown caps. But it does look rather suspicious as everything else worked fine. But the motherboard costs 250$. Which is expensive for a motherboard without 4 x16 slots. and raid12. And if it was just due to overloading, wouldn't it just be a few capacitors, as the CPU, etc etc. all work. It sounds like their just being like those weird car mechanics. (your oils needs changing because the engines breaking the oil. So we're replace the engine instead)
I know it sounds plausible. But convince me im right and that they're fools. The laptop is a slightly old satelite a300 by toshiba
For a week.
