- Oct 29, 2000
So, It appears I may have cross contaminated my loop resulting in it being cloudy (as discussed in this thread)
I think what happened was when I flushed it with Sysprep, and later drained it, I didn't completely empty the loop. Some fluid was stuck in there somewhere. Then the same thing happened when I flushed it with distilled water to get any sysprep residue out, once draining it there was still fluid inside.
Somewhere in one of my threads in this forum someone recommended blowing out a loop with a DataVac blower.
This seems like it might be pretty damned effective. Those are pretty powerful. But is it safe?
The manual for my EK full cover block - for instance - says not to flush it with tap pressure water as it may cause damage and result in leakage. If tap pressure can be a problem, would blowing with a Datavac also be one?
I would - of course - be blowing in one end, with another end open, so I would just be blowing through, but I'm still concerned when it comes to the temporary pressure buildup in the loop.
Appreciate any thoughts!
--Matt
--Matt
