LurkerLito
- Dec 5, 2007
It seems to work for me at 1440p windowed with the 60fps patch as of the 0.5.0 version. If you are running the 0.4.0 version then audio won't work right as it doesn't OOTB play the sound fx files. You'll have to either find the now deleted mod that recompressed the sound fx files, or get the tools and manually do it yourself (it took my rig about 35+ minutes to convert them) with this: https://github.com/Furegato/BloodborneSoundRepack . But it's easier to just upgrade to the latest 0.5.0 version and then reinstall the game and the 1.09 patch.
Once installed and updated to v1.09 right click on bloodborne and select "Cheats/Patches" then go to the patches dialog box. At the bottom select repository shadPS4 and then press download patches.
Then pick check the following: Disable Chromatic Aberration, Disable Motion Blur, Disable HTTP Requests, 60 FPS (with Deltatime), Force Enable Old Hunters DLC and Disable vsync
And it should work fine. At least on my rig for the beginning section of the game.
I had a lot of issues with v0.4.0 I did try the remastered textures and stuff but it caused a lot of weird issues like texture flickering and missing texture maps so I didn't use them when I moved to 0.5.0 of shadPS4. Still I can't close the game without shadPS4 crashing lol, so be sure to look for the .dmp files it leaves behind. I found a ton of them just eating disk space.
