CRASH!
Ouch. Its been more of a Mr. Toad's Wild Ride since it hit $15....
CRASH!
Hi guys, just wondering what mining pool you guys are using these days? I have been out of the BTC loop for a while but as winter approaches I might start up again![]()
Thanks for the suggestions, I will check them out. EMC looks like a neat site. When I was into this I was using GUIMiner but looking at it now it looks like it has not been updated in a long time. Is it still worth using?
cgminer is the best option out right now IMO
Try this calculator
http://www.alloscomp.com/bitcoin/calculator.php
You can also mine with 6970's, hash speed is not influenced by cpu/ram speed or bandwith.
Also It would be more like $5 a month since singles consume 80W
http://www.electricity-usage.com/El...ice=&Watts=80&CostPerKWH=0.105&HoursPerDay=24
Mt.gox is a popular exchange. You are better off mining with a good pool like btcguild because you may never find a block solo mining with the difficulty this high. Also three 6970's would mine at about 1100 mhash
But again, at what...600-700watts, plus the heat dump and cost to cool the living areas of the house.
Maybe if I move them off my primary rig and get some 680s I could stick them in the basement or something.
Thanks for the information Noran
Appears I should wait to see about this Butterfly Lab's Jalapeno "SC"...3.5 GIGAhash/s for 150 bucks....sounds a lot better...sorry, this is probably all rehash for you guys...im just now finding out though.
Yes, there is pretty much no point spending 600 dollars right now for an 832MHash machine (even if it only consumes 80w) when the 2nd generation of asic mining hardware is due out from Butterfly labs.
I inquired about getting in on the first batch of shipments with a pre-order, they said there is pretty much no way anyone that orders now will get part of their initial shipment. I was thinking about picking up 3 or 4 of the "Jalapenos".
The problem is:
1) they have a record of not shipping things on time, I wouldn't want to send them 500 dollars, and then not get anything till next March or something.
2) Once this low power high MHash hardware gets to the public, GPU computing will pretty much be worthless due to the high power consumption and drastically reduced reward.
The block reward is getting cut in 1/2 around Dec (estimated) that's akin to the difficulty doubling overnight. Add in another assload of GHash coming from the butterfly labs hardware (whenever that happens) and GPU's won't be able to mine fast enough or efficiently enough to cover the cost of the power they use. Some have estimated the difficulty would rapidly increase to 10 or 20X it's current level with the addition of trillions of extra hashs being dumped on the "market"
Just like the people that got in on bitcoin when it very first came out... the people that are able to score a Butterfly labs hardware will make out like bandits until the difficulty and price stabilize.
The benefit though is that people that currently use GPUs and can't afford to go out and grab a couple Jalapenos will stop mining, which in turn could keep difficulty levels from going further. I suspect it will have a pretty big impact on pool miners and pretty well wipe out the hybrid use systems. If you can't afford dedicated Ghash hardware then you wont be in the bitcoin game anymore it seems.
An unknown delivery date, combined with an unknown production volume means I keep my money in my pocket
I litecoin mine being that when asics hit and gpu's aren't profitable anymore, lots of people will be switching to litecoin. Litecoin uses scrypt which requires memory which means no fpga or asics is able to mine it with current technology.
Heh, so litecoin is the new thing now eh?Are you making more on Litecoin than Bitcoin? *Goes to check exchange rate
I noticed that some pools are now doing merged mining for both namecoin and bitcoin. Though NMC doesn't seem to be worth much at all, unless you want a .bit domain name..
I dont know about litecoin but I know merged mining gives you less that 1% more profit over just BTC alone. I just donate 100% of my NMC to my pool, it is just not worth my time to deal with the exchange.
can't you register domains with them?
More of a hardware question... Recently exchanged my 6970 for a watercooled 6970. Temps in games range from 50-53ºC, but every time I try to mine for coins within 3-4 minutes the gpu temps start climbing towards 90 before I stop the mining process. Tried pheonix and guiminer with same results. GPU-z shows the 2nd sensor as heating up much faster then the other 2. Any suggestions?
Can take pictures a bit later. Card is a XFX HD-697A-CNFC with EK-FC6970 Acetal (double checked to make sure it was the right revision and it is correct) Case cm sniper, with both sides off at the moment. Overall decent airflow. Only one of the 240mm case fans are running at the moment.
