- Mar 31, 2005
Guess I was Just assuming that was your 24 hour total
This means i'll get .2 BTC when the next block is found,doesn't it tsd?
Hurry up miners!! In stock as of 7:03pm
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=55285&CatId=7005
simplecoin.us by tsd,some [H] members are mining there too.Which pool are you on? .2 BTC per block? That's a big share for 220m/H. I only get 0.08 BTC per block. Then again, I get shares from 38 blocks a day.
Only 4 blocks was found,the most recent one took 6 days.
Fak, currently at around $8 per BTC.
Where you can check/track total network hashes so you could get a feeler on how miners are responding to the low prices or if difficulty will go down?
I wonder why it's dropping so much
Is it true that bitcoin miners are making a significant impact on general AMD card prices? It seems kind of unlikely because the market for GPUs is pretty big.
You betcha. Have you seen the prices for 5 series cards (before this week's drop)?Is it true that bitcoin miners are making a significant impact on general AMD card prices? It seems kind of unlikely because the market for GPUs is pretty big.
On the new card then it's not making a significant impact,true.But for the used HD5000 series,the priced went up due to high demand from miners.Is it true that bitcoin miners are making a significant impact on general AMD card prices? It seems kind of unlikely because the market for GPUs is pretty big.
Bitcoin price will never up to $20![]()
Have to stop mining until i can solve this shitty problem with CCC 11.6b.
My PC has continously freezes with black screen.I thought that was the conflict between Bluray player with Afterburner or something like that.Removed all,still freezed seconds after log in my Windows account.Removed driver,no more freeze or black screen.
Tried to reinstall 11.6,shit happened again.Now i have to wait more than 30 minutes to finish downloading CCC 11.5.
CPU @1.6GHz so it was not related to CPU stability.Go back to stock settings on GPU and CPU and test stability.
Snap,i got only 0.16BTC from this block.Nice. Simplecoin just got a ~3 day block while averaging something like 13 GHash. I've been getting a fairly large number of stales since I switched over. Was 10% at first and now my average is down to 4%. I got my second card today and have it running. Due to heat I'm going to keep my voltage low and limit my overclock. Right now I'm at 913 Mhz at 1.10 volt. I think I can drop that some more but haven't screwed with it yet.
