Bloodgod42
- Nov 20, 2005
According to CoreTemp Beta 0.94, my two cores run as much as 10c difference. Is this normal?
ryan_975 said:It's because core 1 is under a load and core 0 isn't. Try running a second stress test, but assign it to core 0
ococ said:The pics look like both cores are 100% loaded.
Bloodgod42 said:The load seems to be equally distributed...
http://i103.photobucket.com/albums/m132/Bloodgod42/CoreTemps2.jpg
Arcygenical said:Yeah, press hard down on the HSF and see if that helps.
If not, remount using the "line of paste" method rather than the "rice grain" method.
Lastly, RMA the chip to intel for bad IHS quality.
I'm all against RMAing a chip because it doesnt OC well... but these IHS's on the recent Conroes are a JOKE... 300$ processor and the .05c piece of copper is crappy? That's bullshit.
ococ said:i doubt case airflow would make one core hotter than another. what about lapping? Maybe the cpu is uneven and making contact on one side? Are cores split that way?
Bloodgod42 said:Yes, air flow thru the case would not affect individual core, you are correct. I was just thinking out loud that 60c seemed really hot regardless. Lapping is a possibility, since yes, cores are split that way. They reside side by side on one half of the processor.
ryan_975 said:I though AMD's dual core processors are on a monolithic die instead of an individual die for each core.
Bloodgod42 said:You are correct, they are both on the same piece of silicon, but sit on one half of the chip.
http://i103.photobucket.com/albums/m132/Bloodgod42/01.jpg
TrueKaio said:I'd also investigate the temperature sensors. Are others with the same motherboard free of similar issues?
Adidas4275 said:i have similar issue at idle 10*C but loaded they are the same.... maybe the cores are slightly different... we all know diff cpus run at different temps because the silicon isnt the same... could it be the cores are just different and one can be more efficient than another?
ryan_975 said:Both cores are on the same piece of silicon.
Is it possible for the TIM between the IHS and the die to have an air bubble over the one the cores, in turn causing poor heat transfer?
Mr.Pernod said:wouldn't 2 cores, sitting side by side under the same heatspreader eventually reach a similar peak temperature under load, unless one of the cores has poor heattransfer to the heatspreader?
BillParrish said:You are grasping at straws.
Remount the heatsink paying carefull attention to making sure it is tightened down evenly, i.e. alternate tightening of any (I water cool so dont know how this HS is retained on the PCB) fasteners in small stages to ensure even pressure on the heatspreader. Lap the heatsink while you have it off if you have not done so already.
Mr.Pernod said:wouldn't 2 cores, sitting side by side under the same heatspreader eventually reach a similar peak temperature under load?
ococ said:the hs maybe flat, but what about the cpu? not sure about AMD's, but i've seen several concave conroes
Bloodgod42 said:Well, I just reseated the heatsink and looked for any possible cause of the temp diff between core...found none. Fired the system up again and I am still getting the same results...7-10c between cores while loaded.![]()
I dont agree with RMA'ing a cpu just to get a better oc'ing chip, but this is concerning to me. I would rather have both cores running at the higher temp if they stayed within the 2-3c that people are saying is normal for dual cores. What do you guys think? Time to RMA due to defective IHS?
Met-AL said:The software is buggered.
ryan_975 said:Justification: Does the temp disparity exist when NOT overclocked?
Sta!nless said:Hey if this makes you feel any better I have the same problem. Except my core #0 is hotter then core #1. And that's with Core temp beta0.94.
Sta!nless said:Well at idle core0 is 41C and core1 is 26C at 1.47 volts. I really don't think those temps are right though. And at load they are 54 and 48. And I'm using the same version. I might pop the top after I go water. Right now I'm using an XP90 and I hear it's not really a good idea to go neked with that heatsink.
