Best value video card?
MrCrispy
Been out of the loop. I am looking for a cheap card that's quiet and easy to install (single slot). It will be used for light gaming and running HTPC frontends.
I can also wait a month or two if there are some new chipsets/price drops expected soon.
Between Nvidia/ATI, which is the the current recommendation for best value and stability?
I second that. If you don't need that much gaming power though the 4670 is a sweet card.
I'd wait and see what kind of price the 47XX cards come in at. They are supposed to be priced cheap, yet perform somewhere in between the 4830 and 4850.
if your not gaming the 4650 512mb is sweet, about 45 dollars AR and has enough horsepower to do shader functions, like video sharpening, up converting, and other post processing
