Best thermal paste to use?
sequoia
I am getting ready to place a purchase of thermal paste. I was wondering if anyone has any suggestion. AS5 seems to be the popular choice, but what is the best paste to have? AS5, MX2, TX2 ?
I like to use it on the CPU and GPU, if it makes any different
Thanks
Chris
BillParrish
Not really going to make any huge difference, probably will not even make a small difference. Applying it properly and a good "mount" is more important. Use what is easy to get and will not break the bank.
Choppyferrari
Almost all review sites show that the MX-2 outperforms Arctic Silver 5, although I've yet to try it.
firas
I saw in another forum a test over a lot of thermal paste’s to see which makes lower temperatures, the Arctic Silver 5 wasn’t no.1 but most reviews on that no.1 said that its bad and it like sticks for ever or something
(I’ll look it up 4 U if you want)
TheRapture
I had a surplus of AS3 I have been using for years it seems. But in a pinch, stock white paste is fine, trust me, it's not going to make a huge difference when applied properly.
But if you are going to go to the trouble of reapplying paste, might as well use some of the better stuff.
Stillhouse
I've used MX-1 and AS5 and MX-1 always yields at least a degree or two better temps. Plus it's non-conductive and non-capacitive and requires no curing time. You could always buy a tube of both and see for yourself.
Zerikin Loukbel
MX-2 is supposed to be really good: no curing time and non-conductive. I've got a tube I'm going to be using on me new PC.
firas
http://translate.google.com/transla...fe=off&ie=UTF-8&oe=UTF-8&prev=/language_tools
|crappy thermal interface|
Tital Nano Blue 59
Panasonic 58.5
KPT-8 (reference) 56.6
|decent thermal interface|
Data Cooler 57
Titan TTG S-104 , S-103 56.7
Pasta Siliconowa 56.6
Zalman CSL 850 56.5
Noctua 56.5
Stars Silver 56.5
Stars 700/Aero 700 56
GeIL GL-TCP1b 55.6
Thermopox 55.6
КПТ-8(BeO) 55.5
Sil more 55.5
Shin-Etsu(white) 55.5
W.P. 55.5
STARS (white, soft pack) 55.5
AKT-842 55
Fanner 420 55
Koolance 55
|good thermal interface|
Arctic Alumina 55.5
Arctic Silver-3 54.6
AOS 54.5
DC-340 54.5
Asetek 54.5
Arctic Silver-5 53.5
Arctic Ceramique 53.5
|great thermal interface|
Apus TMG 301 52.5
Gigabyte 52.5
Titan Nano Grease TTG-G30010 52.5
GFC-M1 D90T8-010 52.5
Shin-Etsu MicroSi G-751 52
|outstanding thermal interface|
Arctic Cooling MX-1 51.5
Shin-Etsu MicroSi MPU-3.7 50.5
Coollaboratory Liquid Pro 50
see the rev at newegg about the Coollaboratory Liquid Pro
http://www.newegg.com/Product/Product.aspx?Item=N82E16835121005
BigGreenMat
Arctic Cooling MX-2 has been performing great. Not the easiest thing to find in a store near you, but a good performer overall.
The most important thing is application of any of these though. Right now I am getting TERRIBLE temps on my CPU and I am almost certain it is because of the shitty application of a thermal paste pad that came with my cooler. So I figure I will try out a true reapplication of AS Ceramique probably.
magoo
Non-conductive = Ceramique
GPU most recommend ceramique
CPU toss up AS5 or the latest from ArcticCooling, MX-2 I think.
soulfoot
i'm no expert and i have zero expereince but i'm having zero problems with the ceramique on my processor and i'm pretty sure i did a shoddy job and need to redo, but the temps seem to be fine.
ImageMD
I've never tried AS5 (it wasn't out last time I built a system, which was 6 years ago), but I just used MX-2 and had no problems. It was like, $1 more than AS5 on newegg or something.
Brahmzy
MX-2 FTW - I've tried a TON of different pastes and I've had the best luck with MX-2.
