GTX 690 /thread.
I don't think you understand what single slot means in this case.
I am looking for a card that takes up 1 slot only. But still able to use SLI.
My case is a nzxt Vulcan. Micro ate case. I can fit 2 double slot cards in there but the heat becomes ridiculous with 2 double slot cards.
So I figured I would find to single slot cards and SLI them together. So far every single slot card I found is either not made anymore or made by ati and I prefer to have a nvidia for this setup.
I might have to go ati with this since I know the do still have single slot vid cards. With SLI.
GTX 690? It's pretty much 2 single 670s in 2 slots. It's already doing SLI, but can SLI with another (for quad SLI).
I don't get why you would do this. The best air-cooled single-slot cards are mid-range cards at best - even in SLI they pale in comparison to a single higher end dual-slot card. There's just no point.
Basically this. Not sure what single slot AMD card that you think you can run in crossfire that will be better than say a 660TI. Hell even the joke answer of a 690 might be good for you since you did not give your price range or intended use.
This seems silly to get a crappy single slot card so that you have the option to SLI with two crappy single slot cards. Just get a good dual slot card that does what you want it to and ignore SLI as an upgrade path.
That single slow 680 is about the only other option... and that doesn't exist in retail yet...
