The two links you refered too are overpriced the first is the diamond which is and overclocked 4870x2 and is not worth 700+, as well as the HIS is very overpriced for a stock core clocks. The subbrands that ATI/AMD/Radeon sells its cards too are known as the AIB (Add-in Board) partners, like Nvidia's group of sellers (EVGA, BFG, XFX) they all are decent manufacturers. With that being said Sapphire is your safest bet on AMD cards. The best thing to look out for would be heatsinks and included bundle software, this is why Sapphire is a great brand but HIS and Diamond are also top notch. If you are still considering a 4870x2 i would go with this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102768
For you could download Rivatuner and overclock to the higher settings and save yourself about $100. But i would strongly recommend looking into the 4850x2's.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102809
