My video card died today,
I'm looking for the best gaming card around... I've had zero time to research it and I'm hoping you can help me out.
What should I be going for?
GX280 OC?
4870?
Dont care about cost really. (<$650)
4870x2 is the fastest period.
http://www.newegg.com/Product/Produ...description=&Ntk=&SpeTabStoreType=&srchInDesc=
He asked for the best, not the fastest![]()
The 4870X2 hands down right now.
EDIT: jcvjcvjcvjcv: Stop being such a fanboy/troll.
I'm not. For recomendation I always fever the fastest single chip solution. Right now that is the GTX280. But because the GTX280 is that much more expensive ans has a lot of problems I get down to the GTX260 216
Sometimes the HD4870 1GB is a little faster, but mostly not. Combine that with the lower price of the GTX 260 and the higher idle energy consumption of the ATI and I come to the conclusion: GTX260 216
Woes of the 216 Core GTX 260
The only problem we have with the new GeForce GTX 260 is this: it has no right to be more expensive than the original GTX 260, and yet it is. It is no faster than the original, regardless of how many more shaders or texture units it has, and yet it consistently costs more. It is hard for us to see the "revised" GeForce GTX 260 as anything but an excuse for NVIDIA to raise prices back up to where perhaps they should have been competition notwithstanding. NVIDIA maniacally cut prices in the face of stiff competition from AMD, and perhaps cut a little too deep. It is convenient, then, that this supposedly updated GeForce GTX 260 GPU comes out at a higher price tag.
Remember that it was initially supposed to supplement the original GTX 260, not supplant it. All that has changed now, and the "old" GTX 260 is going away. While we can understand that NVIDIA and its partners need to make money as much as any other business, we very much feel like this has been a case of bait-and-switch, and while we're expected to spend more money on this "new" GTX 260, we aren't really getting anything more out of it according to every game we have tested so far. Thankfully, prices on the new GTX 260 are starting to drop this holiday season, and we hope to see that continue.
Everyone, Thank you VERY much!!!
incoming huge post...
This has been very helpful and it confirmed the direction I was thinking I would like to go with my GPU.
Normally I'm always on the up and up about new computer hardware but work has been so busy in the last 2 months that im not current. I just think about computers latly and just get mad because of stupid clients with crappy internet connections, slow routers, no clue how to configure a vpn connection correctly and they all are growling for support. I've been cleaning up all the mess at work but it takes so much time to get them all organized. *whew* rant over.
Also, someone asked about my hardware... the sig is current.
I really wanted to wait and get a card closer to when Diablo 3 comes out because I'm really looking forward to that game and all the vendors seem to get new stuff out there when new huge game titles are on the way. Also with christmas here money is tight... but if I'm going to HAVE to get something now im not going to do it on a tight budget.
I was thinging of waiting like 'needmorecarnitine' said... but I dont want to piss around I just want to get it over with and be able to use my home comp for games again.
My issue is this: I go into games, or ANY 3D application and I get the screen go black for a few seconds and then come back with a frozen picture and then go black again... it will loop 3-4 times then bluescreen. If it happens in windows ill get:
"Display driver nvlddmkm stopped responding and has successfully recovered."
Event ID: 4101
Source: Display
0x80000000000000
If it happens in games it will do its cycle thing 3-4 times and just BSOD.
its a EN8800GTX 512mb. (asus), single, no sli, roughly 2 years old. (beaten to death playing crysis on max everything for a month)
I play @ 1680x1050 max everything.
Thanks again to everyone! I love the [H].
Well, i'm sorry to hear about your card failing; as to your question of best vid card i would tell you what others have said the 4870x2. If you would like my personal opinion though i would go with the 4850x2 as i have been searching around like a mad man : P and have found the from every review site that i have viewed using the current drivers and stock timings that the 4850x2 2gb version is faster than the gtx 280 placing it just behind the 4870x2. I also have found the sapphire 4850x2 2gb for $309.00 minus $20 mail in rebate = $289.00 on newegg. Hope this helps your decision and doesn't complicate your choice more.
try:
turning off uac
Uninstall the chipset drivers, reboot and install the latest from nv.
As a follow-up to my previous post, since your budget would allow, you could pick up 2 4850x2's and crossfire to have the best bang for you buck within your budget.
Price would be $289 after rebate x 2 = $576, which is huge bang for your buck.
The asus rampage formula uses the x48 chipset = crossfire compatible.
Yep, i'm thinking max draw would be 830 watts but your well able to handle it with the Silverstone 1.1kw, check this site out it tested both gtx 280 and 4850x2 with latest drivers.
http://www.firingsquad.com/hardware/sapphire_radeon_4850_x2_review/page4.asp
sounds like alot of work...
I kinda just want to replace it unless anyone pulls a "OHH I KNOW WHAT THAT PROBLEM IS!"
Thanks again everyone for the input!
