Hello. My current monitor is a 27" Dell 2713HM which native resolution is 2560x1440. I used to play games with said monitor but no more. I have always noticed that when working with my office monitor (@1920x1080) though more pixelated I like reading text at said resolution and text is bigger.
I change my 2713HM resolution to 1920x1080 but I don't know if by doing this I will get the same exact result as if my monitor was a 27" one with a NATIVE resolution of 1920x1080? I read this explanation: "Graphics will not look quite as sharp if you work below the maximum (native) resolution. This is due to something called interpolation which the monitor tries to estimate exactly where to put a pixel. That is because the number of pixels is fixed and cannot be changed so it sort of like taking a smaller picture and increasing the size of it until it fits the frame."
Does that mean that given a 27" monitor with a native resolution of 1920x1080 at said resolution it will always look better and show graphics and text better than if I used a 27" monitor with a native resolution of 2560x1440 at the lower resolution of 1920x1080?
If so, which 27" monitor at 1920x1080 would you recommend as the best for using software like MS-WORD, emailing, browsing internet and playing youtube.com videos?
Thank you a lot for your help on this subject!
