Best $150 Intel Proc at Stock
Funky_Junk
Well,
I'm building my new super silent computer to be used for some gaming. Last time I was on the computer scene, a higher clock speed meant better performance. However, as I look for a $150 Intel processor, this doesn't seem to be true, and its leading to some questions on my part.
I'm looking for a $150ish Intel processor that runs cool for my quiet build. In this price range is the E4700, E6300, and E6550. Which one would give me the best performance at stock?
Obviously if they can be had for roughly the same cost, the E6550 would be the winner...
E6300 brings more to the table, as the saying goes: the VT-x support for virtualization, and the E4700 isn't 64 bit capable, as oddly as that seems.
http://www.intel.com/products/processor_number/chart/core2duo.htm
That shows no VT-x support, and no EM64T support either, so scratch any 64 bit OSes and scratch any performance boosts for VMWare/VirtualBox. That's a big chunk of features, I'd say.
Accordingly, the E6550 has it all, with power to spare.
For some reason, that E4700 is the ONLY Core 2 Duo without 64 bit support - so either that's true, or Intel fucked up that listing. I wonder...
Ok, looks like Intel made a mistake (and so did I posting the info above): according to this page...
http://processorfinder.intel.com/Details.aspx?sSpec=SLALT
The E4700 has EM64T support. How very odd.
Well with no overclocking the e4700 should be faster than the e6550. If you are in the US, you can get the e4700 for $20 less than the e6550 at newegg (as of this post that is).
E4700 = 2.6 GHz, 2MB L2, 800 MHz FSB
E6550 = 2.33 GHz, 4MB L2, 1333 MHz FSB
Trust me, the E6550 is faster. The ~270 MHz difference in clockspeed isn't where it comes from: it comes from the ~75% faster FSB and twice the L2 cache. At stock speeds, and when it counts, the E6550 will wipe the floor with the E4700...
If you dont mind used, e6750 will fetch around $140 shipped and if lucky e6850 about $160.
New prices on Newegg for reference.
e6750-180
e6850-190
Well, why is the E6300 @ 1.8GHz more expensive than the E4700 @ 2.7GHZ?
That's because the E6300 has reached EOL since early 2007. Meaning that it is no longer in production. Hence why it's price is so high. In fact, the E6550 was the CPu that replaced the E6300. However, the E6550 has also reached EOL with the release of the E8xxx series of CPUs.
Also, the faster FSB won't provide that much of performance increase IMO. As for the performance benefits of larger l2 cache, check out these links:
Does cache size really boost performance? @ Tom's
Influence of L2 Cache Size on Conroe Processors Performance @ XBit
UT3 Review: Cache Scaling: 1MB, 2MB, 4MB @ AnandTech
2MB or 4MB Cache? @ AnandTech
Oh just wanted to update:
I recommend getting the E7200 instead. It's just as fast as the E6550, can OC significantly higher, and uses less power as well. Not a bad choice for $149:
Intel Core 2 Duo E7200 CPU - $149
Review of the E7200:
http://www.xbitlabs.com/articles/cpu/display/core2duo-e7200.html
Though do note that the MSRP of the E7200 is suppose to be $133. It's a newly released CPU and is in high demand. Hence the slightly higher price. Still a good choice at $149.
