is cloud storage not enabled by default? how do you enable it?
In Origin, there's a litle cloud icon underneath the BF3 entry on the My Games tab.
It just crashed on trying to load the 4th round. Somewhat of an improvement.
no fps actually increased about 5-10 fps
Didn't work for me, cut my fps from 80-100, down to 40-70.
If you are getting stuttering while playing the game and you are running an I7 with hyperthreading try disabling the hyperthreading. As soon as I disabled it on my 2600k the stuttering disappeared... it appears that alot of the stuttering issues with this game are a problem with the way the game uses hyperthreading, and not with gfx cards.
Great... probably back to the BF BC2 issue with CPU multi core optimizations in the NV drivers that were the cause of the problem...![]()
You are correct about that,, not date that I've heard yet though. Just activated my Physical Warfare Pack and now we wait.....
It appears that the 285.62 nvidia drivers are the culprit for stuttering if you use an nvidia card nvidia is aware of the problem and is working on a fix. Apparently the drivers also cause texture and shadow flashing in bf3. Link : http://www.dsogaming.com/news/battl...g-are-introduced-with-nvidias-285-62-drivers/
I think Seine Crossing will be a classic map. Love it!
I just played bf3 for the pc and i noticed that they added a ton of sway to the sniper rifles. I know you can press shi ft key to steady it, but it does not help much because of the recoil.
I do much better as sniper in all of the past battlefield games but they just killed sniper for me. I found myself getting out sniped by assault rifles. I ended up playing assault and realized that it is so much easier to hit someone
with the assault rifle even without a scope. assault rifles should not be more accurate than snipers.
I really hope they change the snipers, they were perfect in bad company 2 and all of the older bf games. They definitely did not have this much sway in the beta.
i too am old school....too bad im not at my home pc to be able to play =[
edit: sorry uploading from playbook..forgot to resize
I think it's a good thing. Snipers are called recon for a reason. They probably added sway to dissuade people like you who just camp for kills rather than helping the team out.
This is the first game that I have had a stuttering issue while using HT though and it is amazing how well it runs when you turn it off. I would say that it is probably a game engine issue seeing as I have never seen this issue before in another game before,
Trying to the same thing with the SVD and MoD1 gets me killed lol.
Is anyone else having problems with 5.1 surround in this game? It's working perfectly in Windows, but when I select "Hi-Fi" in-game it's only passing audio to my front speakers, not the rear. Headphone mode seemed to work fine with virtual surround, as well, so it's kind of confusing.
Should I be setting it to Home Cinema? or what? It worked in the beta on Hi-Fi...
Trust me, it's not the first game to have problems with HT.
wow that is a hell of a decrease....... not sure why it worked for me![]()
Anyone else have this mouse and issues in BF3?? I cannot get BF3 to recognize the center button (under the scroll wheel) or the thumb rest button. Windows and BFBC2 have no issues seeing these.
