Battlefield 3 General Discussion Thread
I hear its buggy as hell and pretty useless, is this true?
Well as soon as I got it I tested it out in an empty server and it does have pretty good range and easier to control that in BF2. I haven't got the chance to use it in combat yet.
But just my luck my G500 mouse is taking a crap on me. Intermittently disconnecting every 2-5seconds. Makes playing impossible and now I cant troll around the map with my new missile unlock. Guess ill be dropping $100bux tomorrow on a G700...
Only $75 on Amazon. Great mouse, battery life is a little lacking, though.
But then Id have to wait 3-5 days to get it. I need my BF3 fix asap ya know? :D
I've always hated wireless and always will. Cant it be used in corded mode though?
Tanks don't have ECM, only thermal camo.
IR Smoke. Both tanks, and aircraft have countermeasures that prevents guided weapons from locking on. They have no effect on TV missiles since you're guiding it manually. Especially effective on land vehicles, when you notice the pilot lining up to fire his rockets at a land vehicle, just switch to TV missile and fire.
As a Recon (a real recon, not a sniper), i've noticed that almost every other tank in the game these days releases them to break the soflam lock. I can only imagine how frustrating it is for a gunner trying to use his guided missiles on a fast moving heli. A clanmate who's a designated helicopter pilot would always tell his gunner not to use guided missiles because it simply takes too long.
I believe so, yeah.
I've been meaning to get one too. My Diamondback has a sticky left button that likes to get stuck a lot... :mad:
If your mouse shopping, I highly recommend the Corsair M60 mouse. I got mine for $60CDN.
Out of interest, how does it feel compared to the G500? I'm getting a little tired of all the wheels on my Logitech mice losing their notch-precision (not sure how to put that, but basically the wheel will scroll up/down on the screen even when not pushed a full notch - really annoying).
I killed choppers with TV missile. :D Fun stuff. It is hard though.
I've taken down a couple jets in addition to helicopters, but that's pretty tough. For some reason even when they're flying straight at you and your TV missile, I somehow misjudge my approach at the very last second and miss. Part of the difficulty is, in hardcore servers it seems to be that the crosshairs for the TV missile are also removed for some reason, so you've only got the bounding box to aim with, which is like half your screen.
I've actually gotten pretty good at taking out enemy helicopters, as long as they're not aware of the incoming missile. A little evasive maneuvers on their part and it's impossible to turn hard enough to get them.
So do the TV missiles actually have splash damage to them now? I remember they didn't used to, and you could hit right next to enemy infantry and do no damage. You could even hit the stationary AT missile launcher that they're manning and do no damage.
my first kill with TV missle was a jet taking a run at me :)
aint easy, 1/3 on the attackhelo that map with it
1 thing I really started to hate about some players they don't know the different target lock tones in the tanks.
I love using the CITV station (3rd seat in the tank) and it seems like every single noob tank I jump in, as soon as I start to laser onto enemy tank, chopper or jet, The driver panics and pop smoke and throw is into reverse at full speed...
Its me locking onto the enemy! Not them locking onto you!!
Every. Single. Tank I jump into does this and its beyond frustrating.
I'm using the emplacement rocket launcher to get the Emplacement Ribbon, still no luck though. The AA gun requires too much waiting.
But a funny moment occurred when I took down an attack heli on Caspian Border with it but didn't kill anyone, only got the disable and destroy. I hit the tail so they had time to bail before it blew up.
Then I was accused of hacking because of the distance I shot it from(US base to antenna, lol), and how it followed them around it.
Well, if you were good at using the AT4 in BC2, shooting helo's out of the sky is simple. It wasn't uncommon for me to go 5 of 5 at any given point.
Since most helo pilots are looking for jets or other helo's to lock onto them, one hit from an emplacement rocket or tow missile will destroy them immediately.
They changed something with the TV missile and how the sensitive it is with the mouse giving it acceleration in the last patch. Since I had it before and I can't stand mouse acceleration this took a bit to adjust, so there were complaints about it.
The other bug is it does have some spotty hit detection issues. You can also blow yourself up at launch despite the patch claiming to have fixed it.
The emplacement ribbon is easiest to get on the US AA on Kharq, especially if the other team is more stacked and will aggressively attack the US deployment.
A question. I live in N America, so if I join a server from S America, Europe etc. what are the chances of bad lag?
Look at the ping (and sort by it) before you join a server. I still don't understand why they don't show it to you in-game, but looking at it before you join should suffice.
If you're joining a European server you can bet on triple digit pings, which is definitely not good.
Yes, it's got a proximity sensor, but that only makes enemies blink of the radar. You need to spot if you want them to appear on the radar more permanently. I fly it around the area just ahead of my squad, especially around or near buildings. If i detect a sensor contact, he's usually either indoors, or squeezed between obstacles, so you can't spot them unless you reposition yourself to their line of sight.
Flying low is more dangerous, but more thorough if you're trying to guide your squad through an area.
And incase you don't know yet. Your ECM gun also triggers claymores. I've killed enemies with their own claymores and that's where i'm getting my MAV kills.
just park the mav in an area and itll get spot points for you.
Protip: many second story windows can be flown into (even if theyre not accessible), just park the mav above some hallway and the enemy wont know why they've suddenly been spotted.
The motion sensor on the MAV is only limited horizontally it seems. You can have an MAV up in the air 500 feet and still detect enemy troops on the ground that are running around.
It's great using it to get to the highest buildings on the map and sniping! Wow I just started leveling up all sniper rifles and this is fun! Does anyone know how to get to the highest building on karkand? The tall building at A, I get up to a certain point and then when I try to get any higher the MAV starts descending, as if the air is too thin. :(
I can't wait for this to be fixed...I feel like the tops of buildings and bridges that are normally inaccessible through legitimate means (no stairs or ladders up) should be designated as restricted areas. Step foot in them and you have 10 seconds to GTFO or you die.
haha. i think they should let you get around still - If you can bail out of a plane and land somewhere it should be legal. mav surfing aint my thing
The 10 second countdown would allow you time to get off if you bail out of a plane onto a building.
Problem is a lot of servers don't show their ping for some reason.
I think it is legit to be up there, but getting there by riding the MAV is stupid and needs to be patched out. If you parachute on there, or land a helo up there and get out fine, but riding a MAV is just ridiculous.
I once parachuted into a spawn beacon on Firestorm and landed on top of one of the light poles. I killed quite a few guys before someone looked up.
Agreed.
I've gotten something like 20 kills on Caspian before, sitting in the base's stationary AA before. Some pilots just get cocky and think they can chase friendlies over our base.
I like the ten seconds to get off a otherwise inaccessible building top idea.
So you remove mav riding, then whats next?
Lamer snipers will be sitting in jeeps with shitloads of mines under em trying to blast there way up.
Take away mav's and they will find some other bullshit way to get up there.
I think parachuting and mav'ing to normally unreachable spots is fine. It takes time and effort to get there time that could be otherwise be spent getting flags and helping your team. Its pretty much only usefully when one team is already wining and has the other team down to 1 or no flags.
I always check high buildings for snipers they are easy to spot and easy to kill for the most part some are more sneaky than others.
Nope, the emplacement AA sucks in this game, must have been patched because I remember disabling aircraft in one pass at launch.
Now it takes many rounds to do so on multiple passes. I even shot infantry in the distance and they didn't die.
Fuuuuuuck, does ANYONE know how to fix the z-fighting graphical flickers in the game? It happens whenever I look down a scope, its annoying as shit and I can't see my targets properly. http://www.youtube.com/watch?v=-pkdUz8o5Q8
Is there some control panel video settings I can change to fix this? (nvidia)
I've been playing for months and now all of a sudden "Disconnected from EA Online" crap that everyone was getting.
The main reason I am against it has to be the uneven games that go on.
These guys will try to argue they are defending flags from afar.
You have no impact on tickets, your a wasted slot.
I am speaking about the guys that get up there and spawn becon right back once killed.
Then they will have support, and assault spawn on them. It's so counter productive.
You basically crutch the team from the get go.
