Batman Benchmark (system specs in sig)
SLI
Physx enabled
1920x1200
No Multisampling
Physx Maxed
Rest of settings maxed
Result: 23fps Low 45fps Avg 61fps High (max refresh for monitor)
Above settings but 2x MS AA
Result: 18fps Low 43fps Avg 61fps High
When I have more time (as I want to play some more) I will switch to 1 GPU and 1 PPU and see what results are.
Batman just cripple my system
I think Mike211 wanted to use SLI for 2 GTX280, and Physx for 1 GTX280?
ATITek: yes, you can. Disable SLI, and select one of the two cards for physx.
Tried bumping the AA up to 16x and it's still smooth
Min - 30
Max - 158
Av - 63
Without a PhysX card (hard to play as stuttery)
Min - 22
Max - 59
Av - 41
Pretty impressive increase with a dedicated PhysX card by taking the load off the main GPU
