firehurricane
- Oct 16, 2011
is reallt different to 6q ?
A bit concerned with purchasing this. I am very weary of backlight bleeding around the edges. Should I be concerned. I have seen reviews of no bleeding and others with bleeding. It's either this of the Samsung S27a350 which cold have the same problem. Any advice. Thanks in advance.
Are you more likely to get edge bleed with a ccfl over led? I ask because I actually have a ve276 on its way to me now but was going to refuse and get the ve278.
What made you decide to go with a ve276 instead of the ve278? Nvmd. I saw it earlier in the thread.
One last thing then I'll leave you alone. Lol. How about horizontal or vertical viewing angle between the two. Any difference?
no difference between the two, both have color-shift like any TN panel will.
I'm considering buying this monitor.
I can't afford an IPS of 2560x1440, cause it would mean to have to buy a new 570 for the SLI and a new power source, and the price difference of the display.
Main purpose is gaming. But I'm a bit concerned about how are small texts displayed.
Are they crisp?
Thanks in advance.
As an update to my previous post, I have received the Huey Pro for calibrating my monitor. I was hoping to be able to share some monitor settings here, but that's not really they way the Huey works. It calibrates your display using icc profiles instead of manually taking you through the monitor osd functions. I can tell you the closest preset available to a properly calibrated setup is the SRGB preset. Using this with the Huey to correct the colors a bit really resulted in a very nice image. I have been very pleased with this monitor. At first I was worried it might be too large, or that the pixels might be too large. After using it for a couple of weeks all I gotta say is that It feels good. It makes my 22" at work feel claustrophobic![]()
I've given up with custom settings and just have it on sRGB now. Sharpness 50 / Trace Free 40. I also use the AI light feature to prevent my retinas from being burnt out.
I was going to buy a huey and give the calibration ago but I can't afford one at the moment.
Doubl0Giggity, I have the same problem check out the forum on it. http://hardforum.com/showthread.php?p=1038330454
Just got one of these today, coming from a BenQ G2400W, which I've had for years. Taking a little getting used to, defintely a lot brighter. Pretty sure I made a good "upgrade" but I'm not quite happy with the look yet, any calibration tips?
I picked this monitor up from Fry's a few days ago. Had a stuck pixel but I massaged it away. Also, it has a slight whine, but only if I turn my ear toward it and even then it's not too noticeable. Overall, I'm really happy with this monitor. The best picture I can expect out of a 27" TN panel, imo.
My local Fry's has the monitor for a good price with a mail in rebate.
I was looking at getting Samsung, but the price on the VE278Q is so much better.
Anyone have any regrets on buying the VE278Q?
