Asus P8P67 Pro Memory Issues
ochadd
Each time my machine is shutdown it fails to start and the red memory error LED on the motherboard stays lit. I've run Prime95 blend, AIDA64 stress, and Memcheck and they all check out ok. Restarting the machine, resuming from sleep, and everyday stability is fine. To work around this:
*Hold the button to power down
* Start it up and it runs for 2-3 seconds, shutsdown by itself, and restarts to show a failed overclock.
* Enter BIOS and do any number of things ranging from nothing, setting memory to Auto, any of the XMP profiles, or manually set the frequency and timings to looser than factory settings and the result is the same.
Using Corsair Vengeance 1866 memory part number CMZ8GX3M2A1866C9. BIOS is the 1053 beta.
This build is turning out to be the most difficult I've ever done. Other issues I'm having:
http://hardforum.com/showthread.php?t=1577235
Does it work if you run the RAM at 1333? There are a lot of people having issues with high speed RAM.
Forceman is right, I had issues getting my machine stable at 1600 (on older 1.65v Corsairs). Once I backed down to 1333, tightened the timings a notch, and lowered the voltage its been stable ever since. At a higher OC with lower voltage even.
Oh and you should upgrade your BIOS to 1204 (be sure you clear the CMOS and start over). It seemed to make things a bit more stable.
I'll try the lower settings this evening.
Where do you get the 1204 bios? Asus website shows the 1053 > 1003 > 0804. Do not see that on there.
This issue has been heavily discussed on the Asus forums. It helped me. I hope it helps you too.
http://vip.asus.com/forum/view.aspx...&board_id=1&model=P8P67 PRO&page=10&count=124
Thanks. That is exactly the same issue. Ten pages of replies and it appears that these mysterious bios floating around are fixing the issue. Also sounds like the CMOS being cleared via jumper, manually setting the XMP profile, and setting the memory voltage to 1.5v is fixing some.
Some of these bios versions appear to be hosted by Asus. Picked one up even though it isn't listed on the driver page.
So my cold boot problem seems to be gone. Updated to the 1204 bios and used the XMP profile to set the memory to 1866. I've only shutdown a handful of times so far but it was happening every time before the change.
That happen to my P8P67 deluxe too, I will to update the bios, thx for the info guys.
Dude,
I feel your pain. I recently decided to buy the P8P67_M Pro and I am having the same issues. I have the same ram you have and this thing just keeps rebooting over and over again. I found a semi fix on Asus Forums to enable wake on PCIE to fix the problem.
OK that worked fine. But for some reason I continue to have a problem where the motherboard will not boot and when it does I get over clock failed. Even though I have it set to Auto.
I let the system run over night with only BOINC running SETI@home to see how it works. get up this morning and the PC hung. I was unable to power it off by holding the power button so I had to turn the power supply off to get it to boot.
I am not sure whats going on but so far I am not a happy camper. I have none of these problems with my WS Revolution build. I am going to try and upgrade the bios and see if that fixes anything. If not this thing going back to Microcenter today.
I upgraded the BIOS and now I am not having any issues. So that seem to fix all of my problems. Everything is functioning properly now. I got the BIOS update from Asus forums. its not available for download yet off there site.
