lolivegarden
- Oct 29, 2007
I encountered my first issue with the board. Whenever I enable XMP the system will refuse to reboot.
I have the same issue
i am liking this mobo based on reviews; however, i'm wondering a few things.
note: the first and last computer i built was around 2002. single agp vid card, pci soundcard, cpu, hook it all up, done
using this picture for reference:
are these motherboards designed around having a dual width video card or will using one block another expansion port? say for instance if you were to install the 1st 4890 in the black pcie slot, would the second go in the white one, allowing you to have the other two pci slots and single pcie slot left for other cards (i.e. tv tuner, capture card, etc.)?
I think this is the video you looking for. More about it in the forum under "Intel Processors - Intel Core i7 920 Overclocking and Heat @ [H]", link in the first post.
http://enthusiast.hardocp.com/article.html?art=MTU4MSwxLCxoZW50aHVzaWFzdA==
Haven't had a chance to read this entire thread, but has anyone tested the eSata port on this board? On my current mobo the eSata port doesn't find my external HDD, though it shows fine on my laptop with eSata or on my system using USB 2. Just curious if this board's eSata works any better.
I have been reading the X-Bit review a lot lately and its hard to see in certain pictures in the review which has clearance or not.
I know that the "Thermalright Ultra-120 eXtreme" has the clearance for 6 sticks of ram (no heat spreaders), but which coolers has the clearance for using 6 sticks of ram? (Please post your experience )
// X
Hey guys, I just got this bored and I have a problem. I'm using Windows 7 64-bit Ultimate and can't seem to get it to see more than 2 GB of RAM. I'm currently using Mushkin Enhanced Blackline 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model 998679
