TwistedMetalGear
- Jun 19, 2005
Just went out of stock as soon as I logged in... Note to self: add to cart first next time!
It's back in stock now.
Yep! I refreshed the page once after I posted that and was able to get one. Thanks!It's back in stock now.
I haven't heard of many complaints with the batches retailers have been receiving in the past couple months. I've also always had good luck with monitor purchases, so I'm kind of banking on that too . My rule of thumb is that for every 1 person vocalizing complaints or criticism on the internet, there are 9 other people who have had a good experience.Hm, with all the reported problems with this monitor, don't you guys who have ordered one feel like you are taking a big chance?
I mean, you don't know if you're gonna get a working model or one with various flaws meaning you'll have to return the unit.
I'm tempted to order one myself but all these reports of bad quality control on behalf of Asus isn't reassuring.
It certainly is expensive enough!
I think buyng from Newegg is taking a chance, because don't they charge a pretty hefty restocking fee?
Best bet is Amazon, Microcenter, and Best Buy because of the free returns.
I seemed to have won the Newegg lottery on this monitor today and have a Fedex tracking number.. Assuming it doesn't have to be returned for all the reported flaws, what's the best setup for it?
I've currently got a 2560x1600 Dell 3014 surrounded by two of my old HP ZR24w's (1920x1200) in portrait mode. Do I just replace the 3014 with the PG278Q or put the PG278Q right next to the 3014 and drop the ZR24W's? My current video card is an EVGA GTX980 and I've got my existing 3 monitors all hooked up via displayport.
For Gsync to operate correctly, do I need to dedicate the GTX980 card to the PG278Q and use a different card for any other monitor?
Looking for some setup advice. I'm tempted to just build out a new PC and dedicate the new monitor to that for just games but that's a bit extreme even for me.
SO TIRED of this goddamn thing only being in stock at times when I can't check for the alerts.
I didn't get an auto notify alert this time, just checked the page. I did recieve one yesterday at 7:04AM but sold out in 20min, was too late for that bunch. Auto notify isn't reliable.
What happens is that you get more motion definition and more motion and control articulation at 100fps+, 120fps+ or 144fps+.
7680x1440 G-Sync Triple SLI GTX 780ti Star Citizen Monster Machine
Depending on your room dimensions and setup, you could try taking over a corner and facing your desk out from the wall instead of the typical against the wall like a bookshelf setup. That gives you more room to swing outward with monitor arms.
Congrats on your good swifts. I'm going to have enough trouble giving a single one enough gpu power even after my potential upgrade to dual 980 sc in sli. I can't imagine trying to feed 100fps+ to three unless it was some source games like L4D2 and dishonored, and some isometric rpg's like path of exile.
G-sync will help with the lower framerate, and as you said you can lower settings to make it go higher. Turning off AA might be a necessity with only 2GB of VRAM at 1440p.Is it worth it upgrading to a Rog Swift when I only have a GTX 770 and won't be able to afford a new graphics card for quite a while?
That means I'll be getting 47 fps on average in Battlefield 4 at 1440p (Ultra, 2 x MSAA) - but I can of course lower settings a bit if necessary.
I have a 24" 144Hz Asus VG248QE monitor currently btw.
Thanks
I would normally say upgrade the graphic card first, but since the VG248QE is a pretty crappy monitor it makes the decision harder...
Just got mine setup. Man, this thing is glorious, and I haven't even gamed yet!
Looking over the panel there is only some slight bleed in the bottom-left corner with brightness set to 20. Uniformity is actually pretty damned good to my naked eye, better than anything I've seen so far. Not one dead or stuck pixel to speak of. The thin, frameless bezel is confusing my eyes and mind right now...
And after being stuck on 1920x1080 for so long, 2560x1440 is a real breath of fresh air. At 27" it looks like the perfect pixel pitch for me. Color blows my old VG278HE I replaced this with out of the water.
Now time to try some games with G-sync already!
The biggest problem was it actually made my eyes hurt; it was too bright. I had to turn the brightness all the way down to zero to stop that but then it just didn't look good. It still felt too bright and too washed out.
I'm afraid I have to join the minority that doesn't like this monitor. I bought one last night and I was disappointed. I've never used a TN monitor before and have been using an ISP monitor for years now. I've read the various comments on this thread and thought I was prepared.
The biggest problem was it actually made my eyes hurt; it was too bright. I had to turn the brightness all the way down to zero to stop that but then it just didn't look good. It still felt too bright and too washed out. I spent a bunch of time messing around with the color temperature, brightness, contrast on the monitor and the nvidia control panel (such as vibrance) and just couldn't get it to a point where I was happy with it.
I perhaps wasn't being too fair since I was mainly using my Windows desktop and not actual in-game usage (although I did try that too and it's definitely nice and smooth). But I use my computer for my job and I need something I can be happy with both in and out of games. I guess I care more about the image definition than I thought I would.
In the end, I decided to take it back and continue waiting for another monitor. It was too bad because the monitor had no flaws. No bleeding, uneven clouding or dead/stuck pixels. I so sad
