Beast Mode
- Feb 18, 2012
I think your "contrast 100" setting is the problem. I haven't had to do anything with ULMB except lower the pulse width to around 90% where it doesn't affect brightness. Colors and brightness at this setting is roughly the same as what I get in non-ULMB with brightness at 20.
If with something like default settings, user color mode and low brightness sans ULMB you have tints then I think you got a lemon with poor color calibration because for me (and according to several reviews) barely any changes were needed to the RGB settings, just brightness reduced.
Thanks, I appreciate the input. Reducing the contrast does not get rid of the yellow tinge, however I can reduce the contrast and then keep the blue channel at 100 and reduce the red and green channels. The end result looks about the same as doing it the other way around (keeping contrast at 100 and lowering all color channels with blue proportionally higher to red and green).
With my custom osd settings ULMB actually looks fine in between 90 to 100 pulse width, it's only when reducing it to ~50 that the image becomes uncomfortably dim.
