jbltecnicspro
- Aug 18, 2006
I finally found a way to enjoy my Swift's epic .25ms strobe motion clarity:
Might as well get an Oculus Rift.
I would like to get 3 of these. I'm not going to pretend my two Titans can handle 3 of these maxed out, but I believe G-Sync may allow for a very playable feel on surround resolutions. But my worry would be the color shift. I've read it's bad on TN on just a single 27'' monitor or larger, let alone 3 of them. Anyone running TN panels this size in Surround or Eyefinity?
Yes, the Eizo isn't the fastest on input lag, but I'd like to know the input lag of the Swift in 120 Hz ULMB mode to really compare. This monitor seems to shine more in the role of G-Sync versus ULMB IMO.
Just read through the whole thing. Looks like this monitor really delivered on its promises. Really impressed with the colour performance for this TN panel. Should be a great upgrade from my VG278HE. Only two more weeks!
woop, finally a full review published at TFTCentral. just reading it all now!
http://www.tftcentral.co.uk/reviews/asus_rog_swift_pg278q.htm
where are all the IPS nazis with their ebay monitors? did they fall into a pit of eternal despair after being consumed by the god of TN?
We wait....and when the time is right we will crush you, coming from an angle you cannot see clearly.
^^ With the continued caveat of: "If you win the Eizo panel roulette" on the FG2421.
Honestly, as a user that loves fast PC's and the ultimate motion clarity I am really only interested in ULMB mode. Having said that and TFTCentral hinted at it, the brightness levels under ULMB are woeful.
You would definitely have to treat this screen like a projector. Some comparisons with IMO the only other "gaming" monitor worth anything out there, the Eizo FG2421.
Ok, so the Swift at 100% brightness and a ULMB pulse duration of 1.9ms (brightest) has a luminescence of 123cd/m2, black point of .014cd/m2 and a contrast of 876:1.
It's motion clarity should be just slightly better than the Eizo as the Eizo has a pulse duration of ~2.3ms. But with that comparison, look at the rest of the Eizo stats:
Turbo240-On, luminescence of 258cd/m2, black point of .06cd/m2 and a contrast of 4290:1. So it's over twice as bright and the image quality just hammering the Swift.
I got very excited when I first saw the chart of the pulse duration of .25, .5, .875. Those would provide EPIC motion clarity results. Until I looked down at the next chart and saw the associated brightness levels.
You may be able to squeeze by in a pitch black room gaming at 50% and 62cd/m2, but for most users that will be too dark. 75% at 92cd/m2 is about the reasonable minimum for a dark room (that produces a very similar result to 10% Lightboost from the VG248QE and it's associated 1.4ms strobe length Lightboost). In a light controlled room at night, the 100% brightness of 123cd/m2 will most likely be the mode used by those who prefer ULMB mode over G-Sync.
Now using the monitor during the daylight even with the blinds closed in most peoples rooms I think will be quite difficult for gaming under that luminescence level. Even at 258 cd/m2 of the Eizo (over twice the brightness), it appears just enough.
To summarize my thoughts: the epic pulse duration settings for motion clarity are too dim to use. At max brightness, the screen in ULMB can be used during the night and in a light controlled room, but won't be adequate during the daytime for competitive gaming even in a light controlled room. That is, unless someone goes hog wild and blocks virtually all outside light.
Also, not sure how Asus plans to allow people to use 3D with this thing. Since those shutter glasses block out half the light from the eyes, we are talking a max of around 60cd/m2 during 3D. Can only be used in pitch darkness really, and will still be fairly dark image.
I guess I'm glad that it does live up to the hype of being a higher-end/"premium" TN panel (looking mainly at color and contrast) but, considering the price mainly, I'm still not sure (for purely gaming purposes) if I want to invest in this instead of a BenQ XL2411Z for less than half the price as my first >60Hz monitor. And then there are options like the Overlord Tempest X270OC which was reviewed recently here. Also $$$ cheaper but lacking some of the features of the other two but also adding some of its own.
You can't compare a 1080p BenQ versus the Swift. Huge difference.
http://www.tftcentral.co.uk/reviews/content/asus_rog_swift_pg278q.htm#comparison
Most of the pro-IPS people around here are simply pro-monitor.
Incorrect.
I'm pro 118$ Tommy Bahama Hawaiian Shirt.
The BenQ XL2720G doesn't use the stupid frame-less casing which ruins the perceived black levels, but is 1080p...
----------------------------------------------The PG278Q seems decent aside from the matte coating, viewing angles, gamma shift, and inner black bezel which makes blacks look grayish and dark scenes look washed out by comparison (not mentioned in the review, but this is true for all monitors which use 'frame-less' casings). They were smart enough to use a matte bezel, but ruined it by option for the 'frame-less' casing.
Maybe paint the innner bezel? Or finely cut some painter's tape to fit with a razor (measured not cut near the monitor face lol). Color that tape whatever color you want first (dark grey perhaps), apply it to the chamfered inner bezel "frame" carefully. No more "blacker than the screen's black" bezelinner black bezel which makes blacks look grayish and dark scenes look washed out by comparison
-- yes that is a shame, I would prefer glossy but might be able to live with it."aside from the matte coating"
[strike=]viewing angles, gamma shift[/s] <-- pretty much any 1ms gaming TN with backlight strobing(and or g-sync) you are going to have to compare it to, and all at 1080p.viewing angles, gamma shift
So you would buy the BenQ over the ROG?
Does refresh rate impact the frame rate at all? I keep reading "you need a powerful graphics card" for all of these high hz monitors but that doesn't make sense to me. I understand that if the game is running at 60 fps then 144 hz will have no benefit, but will it actually hurt performance to keep the refresh rate at 144 hz all the time even if the games aren't reaching 144 fps?
It won't hurt performance, but you'll get tearing and stutter. But that is what GSync is for. It dynamically changes the refresh rate to match the framerate you're getting in the game, essentially, which gets rid of the visual and input anomalies that VSync has.Does refresh rate impact the frame rate at all? I keep reading "you need a powerful graphics card" for all of these high hz monitors but that doesn't make sense to me. I understand that if the game is running at 60 fps then 144 hz will have no benefit, but will it actually hurt performance to keep the refresh rate at 144 hz all the time even if the games aren't reaching 144 fps?
High-refresh capable monitors are kind of pointless if you don't have the horsepower to generate those framerates to match.
G-Sync doesn't work in surround, but ULMB will. I've used ton's of TN panels in Surround/Eyefinity, the viewing angles can be quite distracting.
How does nVidia plan to deal with the display port issue?
it has already been dealt with. they put displayport on their video cards
I LOL'd .it has already been dealt with. they put displayport on their video cardsHow does nVidia plan to deal with the display port issue?
Ah. I should have refreshed the page before posting...I am talking about the RGB problem when using displayport on their video cards.
https://forums.geforce.com/default/topic/699781/displayport-washed-out-color-limited-rgb-/
It might have already been resolved. It's been ages since I last looked at this issue.
I taped my Qnix's inner black bezel before (picture of Korean monitors with the bezel removed) in order to cover the inner black bezel before I painted the bezels (glossy vs matte bezel thread). It's easy to do and might be a good solution for critical users.
THUS where GSYNC comes in. Its whats makes htis display $799 vs $599. People have to realize that Nvidia can and are able to charge a premium for this becasue no one else can offer it.
Im getting one without a second thought.
This thread is like a long echo.... the same shit over and over...
I personally can't wait for this monitor. I am not picky, when it comes to obviously the best monitor when available. The reviews and first impressions are all stellar, and I've read/heard/watched nothing but positive from this monitor. Except this thread.... It's been awhile since I unsubbed a thread. But, I see no reason why I keep coming back here...
