Would two of these ASUS 7970 DirectCU II (CF) fit on this motherboard/case setup ?:
Motherboard: ASUS P8Z68-V PRO/GEN3
Case: Fractal Design Arc Midi
well if Amazon ever ships my two i ordered on the 5th and 10th, and i have got no updates as to when
but they will get EK waterblocks after a 30 to 60 days test, that should cool the VRMs off
Why wouldn't you just buy reference then water cool?
6 ports
doubt it. Two of these require 6 slots all for themselves, with 2 slots empty between them
look at the board layout yourself and see if it does have space for 6 slots, and 16x pcie slots at the top and in the middle.Someone just told me it should fit... can you help me officially confirm/infirm that ?
Damn, that might sound ridiculous, but I have no idea where to look for... I'd need you help for this one if you can
Damn, that might sound ridiculous, but I have no idea where to look for... I'd need you help for this one if you can .
GIGABYTE GV-R797OC-3GD
Here you go (the 6970s are triple slot just like the 7970s, so it should be the same):
http://hardforum.com/showpost.php?p=1037399258&postcount=279
When did you order/what kind of shipping did you use?
Just a heads up, if you want to use the ASUS GPU Tweak with this card, make sure not to get the latest (and worse than RC11) 12.2 drivers from AMDs website. They have compatibility issues with tweak utilities and overall have horrible game performance (Saints row went from 30FPS in sunny areas to maxed vsync 60fps with RC11).
Amazon prime. 1 day shipping.
well, it might be better to have a large solid piece of metal which absorbs heat on one side (i.e. from the PCB) and dissipates on the other through the large surface area.
Strange for you to get a ship notice for something with one-day shipping that'll arrive in almost two weeks...
Silly Asus, save the laser cutting and just add a .50c thermal strip
The higher one is probably for the GPU VRM modules and the other one might be for the memory related power circuits.HWiNFO32 shows me two VRM temp's. GPU VRM Temp 1 and 2. Right now at rest one is 72C and the other 26C.
In my opinion the heat is only radiating from the VGA card's other side where VRMs are located.
Cooling the backplate and/or PCB will not affect VRM temps.
The VRM are connected to the back of the PCB so some heat is dissipated there but by far not as much as on the other side.
... there are parts of them which come out on the back of the PCB too ...
What is the heat like on that setup?
Well, so much for ASUS quality. 1300/1600 can't be stabilized with even 1.3v. 71.6 ASIC quality
