Sparrow_69
- Jan 20, 2004
After a month of research, I finally found the solution to not being able to change the core voltage on my asus 7970-dc2: http://www.overclockers.com/asus-hd7970-directu-ii-top-graphics-card-review
The solution is to use ver 2.2.1.4 of gpu tweak (can be found in the comments section at the end of the review). For some reason, none of the other (newer or older) versions of gpu tweak allow voltage control. I had also tried several version of msi afterburner & sapphire trixx, none of which worked.
This issue was driving me nuts for over a month. I tried several versions of the aforementioned software, different drivers, etc etc. Hope this info helps someone else out!
