Qtip42 said:Very innnnnnteresting.........I have no idea though. I'm thinking it has a single LED doing both blue and red. I'm not sure how they change like that but it might have something to do with voltage level. Maybe when nothing is plugged in, there's only a little power going to it and then when something is plugged in there's more power flowing.
Your guess is as good as mine.
since WHEN did leds start running with ac electricity????Whatsisname said:Dual color leds work by having one color in each direction. One polarity its one color, other polarity, other color. If it's ac it will either blink or be both colors depending on the frequency of the AC signal.
mashie said:Since you were kind enough to offer your services Qtip45 here is something for you.
Where can I find the specifications for the following:
I know it can be masured from any case / CDROM but that is not the answer I'm looking for.
- PCI cover plates.
- The rear panel for mobo trays.
- Front / hole layout for 5.25" devices.
ATX case specifications (for building custom cases)
dimensions specified for ATX, FlexATX, MicroATX, NLX and SFX.
http://www.formfactors.org/devlist.asp?FFID=1&CatID=-1
mc_P said:HI i have an Antec super lanboy case and as you all probably know it has shitty air flow so i was thinking of adding a fan on the window but i dont know how to. help?
- PCI cover plates.
Tricky said:Any tips or sites you can recommend for detail cutting on side-doors? I want to cut out my own window but I want something custom and not just a regular window.
PsyCho_BoB said:Where should I buy a nice panaflo fan? Heard they were good.
delbert said:Wait.
Mashie, (a true modding god) is asking Qtip (a slightly talented know-it-all wannabe) a case modding question??? And then Flecom, a typically fair and knowledgeable guy deserving of his moderator job rails on him for not reading the FAQ? Am I in the twilight zone?
go slowly if its plastic (acrylic and plexi IS kinda plastic)... go slow or you'll end up melting plastic and making it cool into blobs on the sideQtip42 said:The window is probably made of 1/8" acrylic or so I'm guessing. Use that blue painter's tape and tape over the window so it doesn't get scratched (after you remove it). Print out a hole the correct size of the fan you want to use (80mm = 3 inches) ..Use a hole saw, dremel, router, or jigsaw to make a hole. I'd suggest using a holesaw for the best cut. Also apply lubrication to the holesaw itself so it makes a smoother cut. Very simple mod. If you need someone to hold your hand, google "blow holes" and you'll find tons of how-to's.
loldelbert said:Wait.
mashie said:Indeed, I agree totally since none of those documents answer the questions.
Do you really think I would make it that easy![]()
hmm... do you charge for special "services"?FLECOM said:but the nice thing is, i could delete the entire series of posts, and nobody would know except you and me... *twilight zone music*
wayne said:hmm... do you charge for special "services"?![]()
nahh, i m playin, lol![]()
UGHH, not THAT kinda servicesFLECOM said:eeww![]()
oh oh, no i dont do that![]()
UT-Jackal said:Yeah i figured i would just do a double sided tape for a while to see if i like it then move from there. but will it work on this case being that there is a pre-installed window?
"Stick Lubricant" <--- Is that a brand name or a type of lubricant. Just curious, never heard of it before. Thankies.Qtip42 said:Stick Lubricant = if you want to do it right and not have a mess. Costs $3 at homedepot or some hardware store.
Captain Colonoscopy said:"Stick Lubricant" <--- Is that a brand name or a type of lubricant. Just curious, never heard of it before. Thankies.
Qtip42 said:
You can buy a heat gun at most hardware stores, or Lowe's, Home Despot, etc. Most people use them to strip paint off wood so that would be the section to start looking prolly. Be careful, you can melt your sleeving, and your fingers, if you're not careful.wayne said:also, how much are heat guns and where can i buy them?
Kewl, I actually got a project I'm doing for a friend while he's in Florida on business. It's going to be like TLC's "While You Were Out" but with his computer and without cameras. He has this gawd-awful AOpen case with dick for airflow, gonna mod a 120mm into the front for intake, side 80mm intake blow hole and top 80mm exhaust blow hole. Gonna run down to Ace in the morning and see if that lube helps me get ma groove on. Thanks again for the info.Qtip42 said:And about the stick lub..........get the hole saw spinning and then put the stick in the teeth....dont worry it wont kill you or anything.
make ur own window[H]alcyon441 said:Anyone know where I can buy a windowed side panel for my Ahanix Noblesse Mirror (Black)? I have checked ebay and googled but to no avail. I found a lian li side panel on ebay but the measurements were off.
AMDman said:So which one of you can mod/paint a case for me? Qtip? I have $$.
